Trico Wiper Blades
Old Feb 10, 2017 | 08:53 AM
michaelodonnell123's Avatar
Default Trico Wiper Blades
I changed out my old tired wiper blades for some new Trico Blades. The fit is perfect and they work really well. Took me all of three minutes to swap them out. If you are in the market for some new blades for your XK give 'em a try. No disappointment.
Old Feb 10, 2017 | 09:12 PM
pwpacp's Avatar
Sounds great! Are these the frameless models? Maybe share the part numbers too.
Old Feb 14, 2017 | 02:55 PM
Item # 4437136
https://www.carid.com/2007-jaguar-xk...e-4437136.html
Old Feb 14, 2017 | 04:53 PM
Cee Jay's Avatar
Same ones I use.
Old Feb 16, 2017 | 05:20 AM
Jagst's Avatar
Can't seem to get these in the UK?
Old Feb 20, 2017 | 10:08 AM
Boston XK's Avatar
Default wiper blade removal
How do you get the OEM blades off? I have pulled the wiper stalk while pressing ignition (no foot on brake) which puts the wiper blade at a 45 degree angle on the windscreen.
Is there a button or latch that needs manipulating to release the blade housing?
Thanks much
Old Feb 20, 2017 | 11:54 AM
Leave the wipers in the parked position and use your key or standard screwdriver to prise the tab up and you can then wiggle the old blade out.
Old May 26, 2017 | 01:53 AM
Nosferatu's Avatar
So, you use 2x21 inch or one of 21 and one of 22-inch wipers?
