Two questions- Alignment issues/car locked with smart key in the car
Old Dec 1, 2010 | 06:56 PM
jaglover922's Avatar
Brutal, the 08 XKR has caster and camber adjustments in the front. The lower control arm is where you make a camber adjustment. The wishbone, boomerang looking arm in front of the lower control arm is the where the caster adjustment is. So yes there is front camber and caster adjustments on his 2008 XK
Old Dec 1, 2010 | 10:37 PM
Brutal's Avatar
^^^^^^lol, you know I totally glossed over the year we are discussing and was thinking about the 06 and older setup even though we also are talking smart keys...
What would I do without someone to keep me in line Yes youre correct. and since Im now thinking of the correct years.... If you increase the caster, even past recommended spec for more positive caster, this will reduce wander..... also On the locking the key in the car I AM reffering to the microswitch in the outer door handle drivers side not the latch.......
fast40driver
Apr 19, 2024 07:24 AM
msdg137
Sep 16, 2015 06:24 AM
Tony Bow
Aug 28, 2015 05:17 AM
Andrew McVey
16
Aug 27, 2015 07:21 PM
divingmom
Aug 25, 2015 07:54 PM
