upper control arms to neutralize negative camber
Old Jun 23, 2013 | 10:44 PM
toronadomike's Avatar
Default upper control arms to neutralize negative camber
I have already installed new upper strut insulators, lower control arm bushings, and the lower control arm CAM bolts...and still have negative 1.2 degrees camber on both front wheels. I'm not seeing how to resolve the excessive tire wear on the inside edges without neutralizing the negative camber. Has anyone ever heard of Special (slightly longer) upper control arms that are standard on the right hand drive XK8/XKR's which neutralize this negative camber?
Thanks,
Mike
Old Jun 23, 2013 | 11:16 PM
plums's Avatar
Wear on the inside edge is normally excessive toe-out.
hoodun
May 25, 2020 09:08 AM
ym37tech
Feb 8, 2016 01:04 PM
Harry Dredge
Oct 10, 2015 09:33 AM
redgear
Sep 18, 2015 10:05 AM
