Vibration certain RPMs
Old Oct 21, 2021 | 10:26 AM
Khan's Avatar
Default Vibration certain RPMs
My 2010 xkr is experiencing a pretty significant vibration when in manual mode, 3rd gear between 2000 - 3000 rpm. I don't feel it any other time. Any ideas on what it could be?
Old Oct 21, 2021 | 11:14 AM
mosesbotbol's Avatar
Could it be a droning sound?
Old Oct 21, 2021 | 12:58 PM
Khan's Avatar
No sound really. Its just a vibration I feel through the whole cabin.
Old Oct 21, 2021 | 02:11 PM
kj07xk's Avatar
What speed does that translate to? Possible wheel balancing issue? A bent rim?
Old Oct 21, 2021 | 02:21 PM
shemp's Avatar
My 2010 has a slight vibration in all gears around 1800 RMP. Sounds like an exhaust vibration somewhere. One of these days I'll get under there to diagnose it...
Old Oct 21, 2021 | 03:40 PM
Khan's Avatar
I can check the speed tomorrow. Would a wheel balance issue present itself only at certain speeds?
Old Oct 21, 2021 | 04:20 PM
kj07xk's Avatar
It can. Had the issue on one car, years ago, where it was fine up to 60 mph, then vibrated. Above 70 it smoothed out again. Suspension was able to hide it at most speeds except that 60-70 mph range.
Old Oct 21, 2021 | 04:57 PM
jons's Avatar
yes, but in my experience it's more often been uneven brake pad wear, crudded-up brake discs, or a tire flat spot.
Old Oct 21, 2021 | 08:20 PM
tberg's Avatar
My 2010 XKR with about 190,000 miles on it has recently develoed a very light vibration as well. I just put new front tires on last week, so they were balanced, and I had the vibration before the new tires. It is ever so slight but knowing how smooth this car has always been, I do notice it. I'm guessing it;s something in the drivetrain not the tires.
Old Oct 22, 2021 | 05:05 AM
guy's Avatar
guy
or worn tires? cupping of the tires? alignment? worn suspension part…
It was at my last alignment that I learned one of the bolts in the bushing of the strut was about to fail…. I went in for the alignment early that time…. the car didn’t feel right when making sharp left turns at speed and had an unexpected vibration in the car.
Old Oct 22, 2021 | 06:24 AM
I had a similar issue on my VDP and it was the torque converter
Old Oct 22, 2021 | 04:30 PM
steve_k_xk's Avatar
Are you able to determine where the vibration is coming from
That is - rear of vehicle could be diff
If its slighty behind you it could be a faulty tailshaft bearing or
if your feeling up near your feet as suggested by moses it very well could be that the torque convertor needs to be re-balanced.
Old Jan 5, 2022 | 06:32 AM
Khan's Avatar
Swapped out my summer tires for winter, it ended up being a balancing issue. Thanks!
Old Jan 5, 2022 | 07:08 AM
guy's Avatar
guy
Winter tires in Nashville??
Old Jan 5, 2022 | 09:46 AM
Khan's Avatar
Freezing temps, glass transition can happen with the summer tires.
Old Jan 6, 2022 | 06:47 AM
Khan's Avatar
xjtony
Aug 30, 2021 03:11 PM
shma85
Jul 9, 2018 11:17 PM
F1wannaB
Mar 28, 2015 07:41 AM
t54skyblue
Nov 7, 2008 08:14 PM
