Water pump
I checked the coolant Friday and it was low. I added some and then checked yesterday before going to the dealer for an oil change. It was low again. Knowing there are issues with 2010 water pumps, I mentioned it to the dealer. As I suspected, it needed to be replaced. Problem solved.
Many of the XF guys w/ the 5.0L (mine included) have had the water pump replaced.
Leak on mine was not noticeable but the dealer replaced it when I took in for annual service.
you may want to have it checked as it was described as a slow leak out the weep hole. This sounds like what could be happening to yours?
Hope that is helpful and you make out ok
Ozzy_UK
45
Feb 19, 2019 02:05 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
Oct 12, 2015 11:56 AM
