Water Pump modified hoses?
Old Jun 27, 2024 | 11:07 AM
justinhill's Avatar
Default Water Pump modified hoses?
I was looking through the small amount of history paperwork for my car. The previous owner had a new water pump put in. The invoice has no details as to the parts used i.e. manufacturer etc. Under labour though, the line item reads "install new water pump and modified hoses".
Does "modified hoses" refer to something recognisable and commonly done? Since this the the only 5.0 Jaguar I've owned, I wouldn't know what was "standard".
Old Jun 27, 2024 | 03:33 PM
kj07xk's Avatar
You can search for threads here, but I seem to recall some owners reporting the same, as there was a design change in the pump and it’s piping.
Old Jun 28, 2024 | 05:30 AM
bydand's Avatar
see link below.
https://parts.jaguarlandroverclassic.../brand/jaguar/
Have a look under the bonnet, and see if item 6 & 4 has changed to item 7 & 5.
Item 6 and 7 have the same look grey Y piece, but the leg without pipe on 7 is solid plastic? I suppose fitting a Y piece with one leg plugged off and adding this connection justifies the cost from JLR.
Old Jun 28, 2024 | 06:53 AM
justinhill's Avatar
Originally Posted by bydand
see link below.
Thanks! I'll know what to look for when I get under the bonnet. Out of interest, was this a change to fix some problem?
Old Jun 28, 2024 | 08:09 AM
bydand's Avatar
Hard to say.
There is so much wrong with the engine CW pipe work Still, you wonder why they bothered messing with this small pipe.
jbmi
Oct 13, 2021 09:12 PM
Michael?
Jul 23, 2021 11:07 AM
sgk1935
May 4, 2016 09:18 AM
roger.neill
Dec 22, 2013 08:39 AM
perezrp101
Apr 15, 2009 09:02 PM
