Water pump replacement, parts needed
Old Jul 2, 2019 | 04:05 PM
BlueXKR-S's Avatar
Default Water pump replacement, parts needed
Hi
I have 2012 XKR-S (S/C 5.0L). Took it to the dealer for an annual inspection and they found traces of coolant (dry spots) bellow the water pump. Nothing was wet and my level is OK but they suggested water pump replacement. I am considering doing the job myself, but I wonder about the parts needed for the job.
Dealer quoted the following parts:
1. Water pump AJ813909
2. O-ring AJ811539
3. Some tube C2Z18658
Do I need anything else? I've read here that some hoses have changed as well, but dealer did not suggest replacing them and looking at the parts database I cannot figure it out. I've tried searching by part numbers mentioned in different threads here, but they come up as not a fit for 2012 XKR-S
Also, how difficult is the job (in hours)? I have the manual and I've done water pumps on other cars before, but not on the Jag. BWT, car has only 16K miles on it.
Thanks,
Old Jul 3, 2019 | 01:05 AM
badicedog's Avatar
Originally Posted by BlueXKR-S
Hi
2. O-ring AJ811539
Thanks,
Water pumps are no joking matter on these cars. I find it unacceptable to have this issue with only 16k miles on the vehicle. Makes me think twice about selling mine for a 5.0 s/c model. Best of luck with the repairs.
Old Jul 3, 2019 | 05:39 AM
jagtoes's Avatar
Hi
2. O-ring AJ811539
Thanks,
I have found on other cars I've had that if they are not driven much the WP seal has a tendency to dry out and will weep out AF when cold. The normal sign is what the dealer is saying they found with dry AF under the weep hole. This usually seals when the engine warms up but eventually will fail. Also this failure is not catastrophic and you will lose coolant over a period of time. So if this is a sunday driver I would just watch the coolant level each time you take it out and top off if necessary . At 16K miles you have a lot of time to get it fixed as the car isn't used. By the way my old Ferrari required a water pump replacement every 15K miles. With only 16K miles it seems you can take your time replacing it as it is not driven much.
Old Jul 6, 2019 | 09:32 PM
BlueXKR-S's Avatar
Interesting thought, but I would think the seal would be wet all the time since there is always coolant there. I'll get under the car and clean up the dried coolant. Let's see if it comes back.
Old Jul 7, 2019 | 01:31 AM
riverman's Avatar
Default Water Pump Replacement
Hi
2. O-ring AJ811539
Thanks,
The overall design has changed from what you'll see in the manual, so if the thin hard black plastic tube from the "Y" to the throttle body cracks, you'll be replacing the heater outlet tube with the new "Y" and the coolant down tube to the thermostat as well... For your specific questions: You'll need the water pump, its 2 metal gaskets, 2 of the O rings AJ811539 - one for the back of the water pump to the Outlet tube C2Z18658 and one for the back side of the Outlet tube. Overall for the first time doing this job, taking my time, I did it in 5 hours in my modest home garage and I have large hands. PM me if you want to discuss in more detail and tips.
Busa196
Jan 13, 2025 04:33 AM
Joe Gandalf
Oct 3, 2018 12:44 AM
Jim355
Oct 17, 2013 04:31 AM
AntixSD
Apr 3, 2010 07:40 AM
