WD-40 a miracle cleaner for hazy window trim?
Old Jul 4, 2013 | 05:04 PM
pabanker's Avatar
Default WD-40 a miracle cleaner for hazy window trim?
I use WD-40 for every road grime splotch on my cars. It is truly amazing. On a whim, I sprayed some on a clean rag and rubbed down my XK's window trim, which is looking cloudy and matted. Incredible results: the trim now sparkles like new. (And the black grime left on the rag - presumably the oxidized aluminum - was astounding.)
Does anyone know if this is safe for the aluminum? I wiped it a second time to remove the residue, in case leaving any trace of the WD-40 would react and damage the aluminum. Regardless, I strongly recommend that folks give it a go. WD-40... is there anything it can't do??
Old Jul 4, 2013 | 07:04 PM
Doug's Avatar
WD40 is essentially just a mild solvent. I love the stuff. 1001 uses. I keep it in the car, the garage, the garden shed, the kitchen. I use it for almost everything...except as a lubricant :-)
I can't imagine it hurting aluminum, as I've never known know it to hurt *anything*, but others might chime in.
Some folks say it's the worst thing in the world. <shrug>
Old Jul 4, 2013 | 07:28 PM
many have previously posted about the use of WD40 for this kind of thing.....it certainly does work
danke
May 29, 2023 01:01 PM
kevinl
Oct 31, 2019 06:15 PM
OSK_Gomer
Sep 21, 2015 04:33 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
