What did you do to your X150 today?
Old Dec 26, 2025 | 04:34 PM
  #2601
HealeyJag's Avatar
Default Wax on...wax off
Did my yearly wax job today..
Bought a light weight buffer earlier to correct a bird poop stain on the paint..UGH.. gave away my industrial one when I retired....
was SO much easier removing the wax with the buffer. .took less than half the time...
Best $39 I've ever spent...
I even volunteered to help my wife with her Audi!!
Old Dec 26, 2025 | 05:14 PM
  #2602
Circumnavigator's Avatar
Very nice. I'm too paranoid I'll somehow go into the paint or something.
Just going to pay some more talented younger guy to do my color correction and a good 3y ceramic coat in the Spring.
Old Dec 26, 2025 | 05:48 PM
  #2603
HealeyJag's Avatar
An old school painter here,,,painted , color sanded and buffed many Corvettes, Healeys and Jags...
buy one , its so low revs u cant
burn paint..
IMO, ceramic anything is a scam.. WAY overpriced for what???
Will match my 17 yr old paint to any ceramic overpriced finish..
Here she is....
JAX WAX products..
Made in Columbus Ohio
And its not REALLY clean!!!
BO BUCKS!!!!
Old Dec 26, 2025 | 06:05 PM
  #2604
kj07xk's Avatar
So many buffers on the market, which one got your $39?
Old Dec 26, 2025 | 09:06 PM
  #2605
buy one , its so low revs u cant burn paint..
Here she is....
JAX WAX products..
BO BUCKS!!!!
So when I pick you up on the way down to Boca, you polish mine I'll install Mr12Volt in yours.
We are gonna look like twins though, similar to the Celestial Black in color.
Old Dec 27, 2025 | 10:57 AM
  #2606
Today I drove mine to a little breakfast place and had brunch and great convo with @luv2fly .
Definitely built confidence in some of the DIY things on my punch list.
Thanks for the time, stories and tips fellow Navy vet!
Old Dec 27, 2025 | 02:52 PM
  #2607
luv2fly's Avatar
My pleasure. Good to meet and talk cars. With all you have done and plan to do, you'll be one of the go to folks here in no time. Good luck. You've got my number if you need to text a quick question.
Old Dec 27, 2025 | 04:31 PM
  #2608
HealeyJag's Avatar
Will send pics later.
still buffing
Old Dec 27, 2025 | 04:33 PM
  #2609
HealeyJag's Avatar
Baha...
need to replace monitor if I read correctly..
Can't give up my Sirious radio for 3 bucks a month!!!
Old Dec 28, 2025 | 04:28 PM
  #2610
HealeyJag's Avatar
Default Buffer
Job done .. here it is... charger and 2 batteries....works great
Old Dec 28, 2025 | 05:27 PM
  #2611
Sean W's Avatar
@HealeyJag Retired Body works man? Are those Rupes pads? Post a pic of your car since it's clean now!
Old Dec 28, 2025 | 06:30 PM
  #2612
post#2603 above. 😬
Old Dec 28, 2025 | 06:49 PM
  #2613
Sean W's Avatar
post#2603 above. 😬
I saw that rear end pic and the comment "And it's not REALLY clean!!!" He finished the job today so I'd love to see the pics.
Old Dec 28, 2025 | 07:00 PM
  #2614
ohhhhh, me too!
Old Dec 29, 2025 | 04:53 AM
  #2615
Jaguar!2's Avatar
I broke mine this last week, first I managed to scuff a rear wheel taking a tight turn in a busy Christmas car park going to cost £180 to have someone come out and build up, balance sand and paint the wheel, will take about 3 hours to do. That is not the big issue, I have suspected I may have leaking fuel dampers since I got it, however I had found a little vacuum pipe had popped of the SC. I reattached and the petrol smell on start up went away. This little hose though had perished and I replaced it. The new hose kept disconnecting from the pipe it attached to so some stronger method s were done to stop this. All seemed well, I had notice prior diags reporting left and right banks lean so my plan was to tackle this in better weather. She has had new plugs etc, but some exuberant driving the other day, and performance restriction, engine warning flashing and limp mode along with what sound like pinking if old timers remember the valve noise.
So my work list now comprises of damper replacement (I have them just need to fit), front facing radar replacement, restore old speed control module due to software incompatibility and its not the faulty part. Have wheel refurbished. So plenty of spanner time and swearing, but I still think this car is brilliant. For my mods, I am going to look at hydro dipping, this will allow mee to have the carbon fiber look for the plastic engine cover and side pieces. It can be used on this kind of stuff take a look:
https://dipthis.co.uk/process/
Old Dec 29, 2025 | 05:44 AM
  #2616
steve_k_xk's Avatar
Swapped out my 230/8.5mm from my 4.4l for 240/9mm exhaust cams out of an aj26
Old Dec 29, 2025 | 06:15 AM
  #2617
kj07xk's Avatar
So, in theory, opening the valve a bit more will allow the exhaust gas to escape faster? Will you be able to measure any effects of the change?
Old Dec 29, 2025 | 06:23 AM
  #2618
steve_k_xk's Avatar
Precisely and it should shift my power curve slightly higher n the rev band , hoping this compliments my 7200rpm
In terms of measuring the effect it'll be a trip to the drag strip and see if I can increase my mph from my last outing .
Old Dec 29, 2025 | 06:30 AM
  #2619
steve_k_xk's Avatar
That's the theory anyway 😉
Old Dec 29, 2025 | 08:11 AM
  #2620
You won’t regret that mod.
Some have the Supercharger lettering stenciled.
Don’t forget the two covers near the windscreen!
