what rpm should an xkr engine idle at
Old May 23, 2014 | 01:41 PM
powerhouse's Avatar
Default what rpm should an xkr engine idle at
my xkr 07, has an erritic idle sometimes, never goes above 1000rpm, but jumps from 500 to 1000 any ideas, using good fuel and all new filters fitted, driving ok. What should it idle at.
Old May 23, 2014 | 03:16 PM
amcdonal86's Avatar
Does it have an erratic idle when cold? My XKR has an erratic cold idle...
Old May 23, 2014 | 04:49 PM
powerhouse's Avatar
Default erratic idle
yes sometimes, drove it 15 miles this evening and when stopped it was a bit jumpy on the rpm needle. Driving no issues, just one morning i started it and it died, started second time ok
Old May 24, 2014 | 04:57 AM
JagV8's Avatar
Same engine as STR I think. Mine idles 600-700 sort of range, very smoothly. Switch off a/c in case it's part of the cause. Beyond that, go looking for things affecting fuelling (air leak, dirty MAF, bad IAT/ECT/etc sensor, bad coil, bad plug, ...). OBD can diagnose most and OBD live data lets you literally watch the values.
toronadomike
Jan 22, 2026 10:13 PM
obwoodie
Sep 3, 2015 07:45 PM
OkieTim
Sep 2, 2015 12:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
TC Johnson
Sep 2, 2015 09:30 AM
