What tool tightens the metal collar below the shift knob?
Old Jan 14, 2024 | 03:28 PM
howdoyousayjaguar's Avatar
Default What tool tightens the metal collar below the shift knob?
Thanks!
Old Jan 14, 2024 | 05:59 PM
Cee Jay's Avatar
Lots of info here:
https://www.jaguarforums.com/forum/x...009-xkr-97554/
Sometimes Search doesn't work, sometimes it does.
Old Jan 14, 2024 | 08:57 PM
Stuart S's Avatar
Originally Posted by howdoyousayjaguar
Thanks!
It appears that you inquired in the wrong Forum. This is the X150 Forum, for 2007 - 2015 aluminum XK/XKR models. Your 2003 XK8 is the previous generation X100, from 1996 - 2006, here.
Old Jan 14, 2024 | 10:37 PM
jahummer's Avatar
Well the picture’s of an X150 so I reckon the OP’s asking in the correct forum.
Old Jan 15, 2024 | 03:36 AM
RichardS's Avatar
It looks like an X150 to me as well.
Richard
Old Jan 15, 2024 | 06:20 AM
Sean W's Avatar
To the OP, my car is stored away but it is either an Allen wrench or Torx. Can't recall but I used one or the other to remove mine recently. As both tools come in sets, you should be able to match it up quickly.
Old Jan 15, 2024 | 08:32 AM
Stuart S's Avatar
My bad. I based my reply on the OP's signature, which says that he has a 2003 XK8.
Old Jan 15, 2024 | 08:54 AM
Originally Posted by Sean W
..... it is either an Allen wrench or Torx. Can't recall but I used one or the other to remove mine recently. ......
I no longer have the 4.2 but my recollection is the same.
I also think the chrome collar is more decorative than contributing to attachment of the knob. The gear knob is screwed on and then the collar adjusted to be a snug fit against it to avoid leaving any unsightly gap.
It's been six years since I did this so memory could be playing tricks!
Old Jan 15, 2024 | 09:13 AM
jahummer's Avatar
Graham's correct, it's a special pin tool which holds the collar, then the knob unscrews. Usually it had some thread lock on it so it can take a firm left turn to loosen.
Old Jan 15, 2024 | 09:59 AM
Stucciarello's Avatar
I removed mine last summer to replace the shift gate cover. The shift knob is easily removed by gripping and unscrewing it, that collar can then be unscrewed. To reinstall, screw the collar down the threads then put some lock tight on the upper threads and screw the knob down. Screw the collar back up to meet the knob and allow the thread locker to dry. This can all be done without tools.
Old Jan 15, 2024 | 05:37 PM
wymjym's Avatar
the tool iscalled a c pin spanner wrench amongst other names…
but I also removed mine with just a tight grip, no tool needed in my case.
wj
Old Jan 16, 2024 | 01:41 AM
I drive an XK!
The XK8 was my first cat.
Old Jan 16, 2024 | 01:47 AM
Originally Posted by Cee Jay
Lots of info here:
That thread is actually why I posted here. I couldn't find the tool name.
Old Jan 16, 2024 | 02:32 AM
I drive an XK!
Members see the details in your forum Signature (boxed in RED) and NOT the one shown in your Vehicle Info (boxed in GREEN):
Time for an update.
Old Jan 16, 2024 | 06:51 PM
Time for an update.
If I had known members would ignore my thread photo and click through to my profile, I would have changed it ASAP lol. Who knows, I could have been asking for my dad or something to that effect.
I think people can tend to get overly corrective here. Someone suggested I use the search function, yet if they had done that themselves they would have seen the question hadn't been answered. If the point is to avoid wasted time and space, it seems a little counter productive.
That all being said, I in no way mean any disrespect to the mods and all the time and effort they put into the forum.
Old Jan 16, 2024 | 08:11 PM
Cee Jay's Avatar
.........Someone suggested I use the search function, yet if they had done that themselves they would have seen the question hadn't been answered. If the point is to avoid wasted time and space, it seems a little counter productive..............
That was me. I showed you NINE threads with pertinent information, each with many replies. WHY would you think that I'd care to search all those hundred+ threads to find YOU an answer? I don't even have that shifter, and don't give a crap about knowing the nomenclature of a "pin Spanner, just use some Non-Marring pliers like the rest of the world.
You also could have stated "Searched, couldn't find anything."
Go ahead and get pissy though, if that's what you want to do. That's what MOST new members do anyway when nobody instantly provides them with the exact factory-approved methods and equipment instantaneously for their exact problem.
****, man. I usually don't get riled up so much.
Old Jan 16, 2024 | 09:12 PM
McJag222's Avatar
howdoyousay
Old Jan 17, 2024 | 11:02 PM
I think putting *searched is a great idea. I'll do that in the future. I apologize if you were just trying to help. I took it as a "why are you posting this, just use search" comment, which was frustrating since i always search first. But you wouldn't know that, so I see your perspective.
I'm actually not a new member. I joined 9 years ago when I got my first, an XK-8. I strayed to Porsche, but saw the error in my ways and returned last month with an XK. It's the most beautiful, well built car I've had.
Old Jan 17, 2024 | 11:42 PM
Originally Posted by McJag222
howdoyousay
Lol. That's a way better name
Old Jan 18, 2024 | 09:01 AM
panthera999's Avatar
Remember it's easy to grind down a square tip (widely available) or a larger round tip. Or a file if you feel like an Amish farmer. I found the right size C-wrench tip to be a tough search.
