wheel bearings woes
Old Apr 3, 2025 | 08:39 PM
badicedog's Avatar
Default wheel bearings woes
Hello gentlemen, seems like I'm hearing the "angry bearing" sound form the rear passenger wheel. I noticed my MPG has decreased to 15 mpg. I this a project one can do on own or need to be taken to a shop? Thank you. 2009 XK with approx 65k miles. Not driven hard at all.
Old Apr 3, 2025 | 09:20 PM
SNAPCHAT's Avatar
Got 4 bearings on the way at the moment, hearing the same thing. Not sure what the job entails quite yet, but I will be following this post! Will update if I finish before anything on here happens.
Old Apr 3, 2025 | 09:26 PM
badicedog's Avatar
I'm just ordering the bearing set now... I will update as I progress on this...
Old Apr 3, 2025 | 11:06 PM
badicedog's Avatar
found this informative video
Old Apr 4, 2025 | 02:10 AM
SNAPCHAT's Avatar
So the guy in the video (watched pt 1 and 2) bought a new hub + bearing assembly - he did not remove the bearing from the old hub and reuse it. I am trying to find something online on whether or not you can just bolt a new bearing into place on the old hub or if you need to have some special tool like a press. If the bearing can just slip/bolt onto the old hub, this job will be cake.
Old Apr 4, 2025 | 03:37 AM
RichardS's Avatar
You definitely need a press for the wheel bearings on the X100 unless you replace the complete hub assembly. I would expect that the X150 will be the same.
Richard
Old Apr 4, 2025 | 06:55 AM
badicedog's Avatar
I ordered a new hub assembly with bearings. Pressing out the bearing on the hub seems like a shop job and NOT a DIY…
Old Apr 4, 2025 | 06:36 PM
SNAPCHAT's Avatar
Richard
Looks like I am back to shopping. Thanks!
Old Apr 4, 2025 | 08:59 PM
badicedog's Avatar
I ordered from RockAuto, both hub assemblies $180
Old Apr 5, 2025 | 07:44 AM
SNAPCHAT's Avatar
Yep, total was $390 for all 4 of em
Old Apr 7, 2025 | 11:35 AM
luv2fly's Avatar
Are you positive it is the wheel bearing and not a differential side bearing or pinion bearing?
Old Apr 7, 2025 | 10:17 PM
badicedog's Avatar
Im following the KISS method and OCCUMS razor. The sound is coming from the rear wheels, I distinctly hear it louder when driving on FWY next to center divider. Axle/Knuckle bearing seems to be the culprit to me. If the noise continues, I will have to re evaluate the situation.
Old Apr 8, 2025 | 07:41 AM
luv2fly's Avatar
I asked because I've had to replace the differentials in both mine. It's not uncommon. If the noise increases under acceleration/deceleration, it's the pinion bearing. If it increases when turning one direction or the other, it could be wheel bearings or differential side carrier bearings. Jaguar had a TSB about this and the diffs were replaced on some cars prior to the e-diffs in 2010.
Best to get the car on a lift and if the traction control will allow, with the rear wheels turning, listen to the wheel bearings and diff with a mechanic's stethoscope.
It's very difficult sometimes to separate bearing noise from tire noise. And noise increasing driving near the center divider makes me think tire unless the center divider is a concrete wall and reflecting the sound of a wheel bearing going.
I agree with KISS, but in my case I've never had a rear wheel bearing go out on my Jaguars, but 2 diffs.
Trying to help, not make things more difficult.
Old Apr 8, 2025 | 02:56 PM
badicedog's Avatar
The center FWY dividers are indeed concrete. Fingers crossed its wheel bearing noise reflecting back to the drivers seat. I have not paid attention if the noise increases while turning or not. I will keep an ear out. Thank you so much for your input
Old Apr 11, 2025 | 02:40 PM
badicedog's Avatar
Murphy’s Law strikes!  Hub assembly doesn’t seem to fit.  Splines do not slide in… very tight fit, even with weighted hammer/mallet.  Fudge!
Old Apr 12, 2025 | 05:48 PM
badicedog's Avatar
UPDATE: both rear hub assemblies, replaced after first replacement parts from Parts Geek did not fit. Beating type noise is still present… like a cricket chirping in the middle of the night driving me CRAZY!!
Old Apr 13, 2025 | 08:10 PM
badicedog's Avatar
considering the wheel bearing have been changed out, next suspect differential?
Old Apr 14, 2025 | 08:35 AM
wymjym's Avatar
rear control arm and rear tie rod (knuckle side)
will squeak when worn.
wj
Old Apr 16, 2025 | 05:38 PM
badicedog's Avatar
I've been paying close attention to the beaing type noise. It seems that when I brake it gets louder and when I turn to the right. Any ideas?
Dmcr
Dec 15, 2021 03:29 AM
meirion1
May 11, 2021 09:14 PM
wcourt3010
Sep 23, 2015 01:06 PM
awil
Sep 30, 2013 01:27 AM
GSE100
Dec 3, 2007 04:47 PM
