wheel bearings woes
Hello gentlemen, seems like I'm hearing the "angry bearing" sound form the rear passenger wheel. I noticed my MPG has decreased to 15 mpg. I this a project one can do on own or need to be taken to a shop? Thank you. 2009 XK with approx 65k miles. Not driven hard at all.
So the guy in the video (watched pt 1 and 2) bought a new hub + bearing assembly - he did not remove the bearing from the old hub and reuse it. I am trying to find something online on whether or not you can just bolt a new bearing into place on the old hub or if you need to have some special tool like a press. If the bearing can just slip/bolt onto the old hub, this job will be cake.
I ordered a new hub assembly with bearings. Pressing out the bearing on the hub seems like a shop job and NOT a DIY…
Im following the KISS method and OCCUMS razor. The sound is coming from the rear wheels, I distinctly hear it louder when driving on FWY next to center divider. Axle/Knuckle bearing seems to be the culprit to me. If the noise continues, I will have to re evaluate the situation.
Best to get the car on a lift and if the traction control will allow, with the rear wheels turning, listen to the wheel bearings and diff with a mechanic's stethoscope.
It's very difficult sometimes to separate bearing noise from tire noise. And noise increasing driving near the center divider makes me think tire unless the center divider is a concrete wall and reflecting the sound of a wheel bearing going.
I agree with KISS, but in my case I've never had a rear wheel bearing go out on my Jaguars, but 2 diffs.
Trying to help, not make things more difficult.
I asked because I've had to replace the differentials in both mine. It's not uncommon. If the noise increases under acceleration/deceleration, it's the pinion bearing. If it increases when turning one direction or the other, it could be wheel bearings or differential side carrier bearings. Jaguar had a TSB about this and the diffs were replaced on some cars prior to the e-diffs in 2010.
UPDATE: both rear hub assemblies, replaced after first replacement parts from Parts Geek did not fit. Beating type noise is still present… like a cricket chirping in the middle of the night driving me CRAZY!!
will squeak when worn.
wj
wcourt3010
Sep 23, 2015 01:06 PM
