Windscreen Washer fault
Old Apr 4, 2016 | 04:02 AM
Ozmag's Avatar
Default Windscreen Washer fault
Hi,
My 08 XKR has an issue with the windscreen washer unit, the pump works as I can hear it, the line is clear but it won't pick up the water. Any ideas?
Old Apr 4, 2016 | 06:43 AM
kj07xk's Avatar
Originally Posted by Ozmag
Hi,
If you're absolutely sure that there are no obstructions in the line, it's got to be the pump. Making noise, but not functioning.
Old Apr 4, 2016 | 11:06 AM
michaelodonnell123's Avatar
Maybe the pump and hose are fine but the final nozzles are clogged up. Disconnect the hose before the washer nozzle and run the pump....and see what happens.
Old Apr 5, 2016 | 05:08 PM
Ozmag's Avatar
Probably the pump, no obstructions in the line or nozzles
Old Apr 23, 2016 | 05:41 AM
Ozmag's Avatar
And now it has started working again, perhaps it was an airlock??
Old Apr 26, 2016 | 01:51 PM
ejjbee's Avatar
When I got my XKR some 4 years ago, the pump would not pick up water. Lines and nozzles were all fine. Located problem to washer tank - lack of use and somehow there was a sediment blocking the output from the tank. Removed line from wipers (from the T connection if I recall correctly as the connection is some form of valve) and blew into the washer tank. Problem sorted.
Jagman28
Sep 18, 2017 02:42 PM
bklynchris
Mar 19, 2016 04:14 AM
hawaiianjag
Mar 17, 2016 05:58 PM
ejjbee
Mar 17, 2016 10:24 AM
Xkrjoe
Mar 13, 2016 05:58 PM
