Wiring help for backup camera
Old Nov 11, 2019 | 09:05 PM
badicedog's Avatar
Default Wiring help for backup camera
Evening guys, I’m installing a clip on backup rear view mirror. The mirror has an integrated front facing camera that records cont in a 3 hr loop. The rear camera is HD but wired. I need help identifying the reverse light positive wire in the rear trunk. The front mirror also needs switched power. I was thinking of using one of the power wires from the overhead center console due to its proximity to the rear view mirror. Any other suggestions/help is most def welcomed and appreciated.
Old Nov 11, 2019 | 09:25 PM
Sean W's Avatar
The reverse wire in the aux (rear seat junction box) on LHD is Orange/Yellow wire in CA23 in the pic below and is the easiest place to access it. It's also easily fished through to the boot if you splice it there as many wires go through on the right side.
I don't think any of the mirror wires are switched.
Old Nov 11, 2019 | 09:34 PM
Sean W's Avatar
CA103/9 is a delayed switched source in the overhead console that should work. The plug is 20 pin. wire # 9 is Red/ Green
Old Nov 11, 2019 | 09:56 PM
badicedog's Avatar
thank you
OnFire
Oct 4, 2023 06:49 PM
dougsteve1
Nov 2, 2018 04:23 PM
Obelix
F-Pace (X761) / C-X17
Oct 21, 2017 08:04 PM
wilky
Feb 21, 2015 08:22 PM
Spikepaga
Apr 17, 2013 09:11 AM
