This would be AMAZING!! If one could do it?
Old Jul 10, 2025 | 10:51 AM
Obtuse1's Avatar
Default This would be AMAZING!! If one could do it?
I’m sorry I’m just a newbie here- not to cars but the jags. And I have just been searching the forums and it seems like I go in circles- different cars, different models, dates on reply’s from 10 years ago. And now parts are always improving.
If someone could put a list together of the normal parts that are going to need to be replaced in the X150s Particularly (for selfish reasons) the current 2009-15 5.0 supercharged XKR with the part number or part brand, (at least what fits or interchanges in the yrs mentioned) the cheapest place to get it, and the things that need to go with it. Maybe even what should be done at the same time. For example, if you’re replacing the lower pulley, is there something else that can be or SHOULD BE replaced? I.e. S/c solid snout? Water pump? That would make it easier while that is being done to be proactive and stay ahead of the curve in terms of things that are going to need or have to be replaced at some point in the near future!!
for example a consensus list of the best current options of proven reliable upgraded parts?
coolant system parts?
water pump?
intercooler pump?
themostat?
rotors and brakes?
maintenance items?
what hoses?
etc…
Such as… oil change frequency?
differential oil change?
s/c oil change?
radiator flush?
what are some maintenance things that should all be done and how often? When should they be done and should they be done staggered or altogether or when something else is being done to make it cheaper and simpler? I know that the owners manual has a lot of this information in there, but sometimes it’s hard to decipher and sometimes the knowledge of the forum members here might supersede some of the information or be more encompassing than the information gathered in the owners manual. Not only from just knowledge, but from experience as well. Maybe put it in a sticky?
As a matter of fact, whoever can put something like this together and post it so us newbies have everything in one place (I’m ocd so I need a concise, all in one place list) so I can focus- I will send a set of brand new jag growler valve stem caps! Retail price 2,015,096.45. (Gambian bututs)
*void where prohibited by law. Not responsible for error or omissions. Please read the small print. In case of disagreement, all parties shall agree or disagree to arbitration within the contiguous United States with final decision therefor hereto, thereunto within and so forth be legally binding notwithstanding, and where illegal, then shall be rendered null and void.
in all seriousness, I will send somebody a set of new valve-stem caps, and you will have my respect and admiration for life!
Old Jul 10, 2025 | 12:44 PM
wymjym's Avatar
Great idea but 'someone' would need to dedicate his/her life to this list (project).
Maybe as AI improves you could add the appropriate queries and commands to ultimately organize this information.
Until then I suggest you search this website and add information as you find it to benefit everyone.
WJ
Old Jul 10, 2025 | 02:32 PM
Circumnavigator's Avatar
While I love the idea, I’m with this 👆guy.
Now, that said, I am extremely AI fluent, use it daily work and leisure.
And believe it or not, during my search for my first XKR, I’ve used it quite a lot. And it references these and other forums, FB groups and of course all articles & has access to the service docs I see here.
If someone were to compile just a link to “the best most comprehensive” thread for each topic, I could easily drop it in AI and work through drafts with one of the experts here to get it to a final state.
Old Jul 10, 2025 | 02:34 PM
Let me add:
It would not be advisable to have any time relevant things such as:
shop names
parts sourcing
urls to items.
as they would be outdated the day it is published.
Old Jul 10, 2025 | 02:48 PM
As a quick example, in under 5 mins I had it scan the Pinned thread for XK/XKR DIY stuff.
told it to analyze #11 maintenance including links in that section and provide a simple summary of its contents.
the results:
- Maintenance check sheets for Jaguar vehicles up to 2009 and from 2010 onwards, including schedules for XK/XKR X150 models (source: https://www.jaguarforums.com/forum/x...1/#post2173730).
- Fuel system cleaning every 12,000 miles for 5.0 engines, with recommendations for valve and injector cleaners (source: https://www.jaguarforums.com/forum/x...1/#post2173730).
- Water pump replacement, noted as a common fault (source: https://www.jaguarforums.com/forum/x...1/#post2173730).
- Transmission oil filter and supercharged oil replacement via DIY methods (source: https://www.jaguarforums.com/forum/x...1/#post2173730).
- Ancillary and supercharged belt replacement (source: https://www.jaguarforums.com/forum/x...1/#post2173730).
- Spark plug replacement (source: https://www.jaguarforums.com/forum/x...1/#post2173730).
- Use of Techron for fuel system care (source: https://www.jaguarforums.com/forum/x...1/#post2173730).
- Service summary spreadsheet for XK 5.0, covering service history (content not fully accessible) (source: https://www.mediafire.com/file/0t0yn...tory.xlsx/file).
- Service indicator reset procedure, involving specific button sequences with the ignition (source: https://www.jaguarforums.com/forum/x...63/#post899539).
- Jaguar special tools, including the PDU for diagnostic or maintenance tasks (limited details available) (source: https://www.jaguarforums.com/forum/g...-tools-187726/).
- Jacking the vehicle using specified points (A for jacking, B for stands), with cushioned pads to prevent damage (source: https://www.jaguarforums.com/forum/x...ts-xkr-187308/).
- Axle stand placement on rails or cross members, including stability checks before working underneath (source: https://www.jaguarforums.com/forum/x...ts-xkr-187308/).
Old Jul 10, 2025 | 04:06 PM
Obtuse1's Avatar
WJ
yes, I understand what you’re saying. I guess I was not referring to maybe not so much an all encompassing list but just some of the few things that- as a newbie to this world, what are some fairly common items in terms of things that initially need to be checked and replaced within the first six months or so. I know that this is subjective, but I was thinking like water pump, intercooler pump upgrade, maybe the coolant pipes thermostat etc. especially if someone is going to be modifying i.e. lower pulley, tune, etc.Because I know it seems like everyone is using certain brands for certain things and maybe just a starting list of 10 items? And as a person replaces or possibly buys something and has a good experience with it or finds a decent price they could just go over to that sticky and put a notation in. Maybe more beneficial would be a brand that has failed several people and a warning to absolutely stay away from. With a Toyota FJ 40 that I had, I compiled a pretty good list of part numbers for common components that needed to be replaced after 15 to 30 years like radiator, water pump, thermostat, for people that wanted to go OEM, but the cost was not as prohibitive as what OEM parts are with Jaguars and next to the part number — if it was discontinued or obsolete, it would be noted there, but it was a way to research the part and see what the manufacturer specifications were.
Just an idea because it seems like the questions that I’ve asked on the forum don’t get a whole lot of answers or opinions, and I know there are parts that people have replaced. So when I search the forums, I find things that people are using, but it would be from a thread from 2012 or 2014 doesn’t seem like for people like me that there’s a lot of information in newer post and most of you guys have already replaced the parts or components that needed to be replaced.
Old Jul 10, 2025 | 04:16 PM
Originally Posted by Obtuse1
yes, I understand what you’re saying. I guess I was not referring to maybe not … the parts or components that needed to be replaced.
Just use AI.
i provided the top level URL for the X150 section and had it scan for anything applicable to the jag I’m looking at tomorrow.
Asked it to find specific things to look for myself as a non mechanic, what to have the PPI guy look for, signs (oil, liquid, noise) that indicate a potential or impending issue.
Spit out a laundry list of specific things and made it a PDF for me.
Heck, at risk of legal issue I may even get a copy of the SSD running and have it rewrite it to run in a modern laptop without a VM.
Old Jul 10, 2025 | 04:22 PM
Here is the punch list for a 2010 xkr vert with high miles. It got this from the forums.
Of course I had it break some down into more detail like the noises… but this was the initial summary.
i may have it add photos.
### Things I should be concerned about
- Front crankshaft pulley oil seal leaks, which can develop splits and cause minor but persistent oil seepage, especially in high-mileage vehicles.
- Wear on timing chain tensioners, guides, and sprockets, potentially leading to engine performance issues or unusual noises.
- Presence of exhaust gases in the cooling system, indicating potential engine problems in 5.0L V8 models.
- Incomplete or unreliable service history, as CarFax may miss key maintenance, increasing the risk of hidden issues in expensive-to-repair cars.
- Degradation of the valley hose in the V8 engine, which can fail over time.
- Suspension component wear, including bushings and boots, due to age and mileage.
- Leaks in the passenger rear footwell, possibly from the convertible top, AC condensation (failed duckbill drains), or quarter window seals.
- Aging rubber and plastic parts like hoses, belts, and thermostat housing, which may break due to heat cycles and lead to overheating or insufficient heating.
- Sticking exhaust bypass valves, affecting exhaust sound and performance.
- Ticking noises from the high-pressure fuel pump (HPFP), which could indicate wear or impending failure in direct injection engines at high mileage.
- Oil cooler failures leading to leaks and potential oil-coolant contamination.
- Water pump issues, as they are common in 5.0L engines and may require proactive replacement.
### Things I should look for as a non-mechanic
- Oil residue or thin spreads around the bottom and front of the engine, especially after shutdown, indicating possible crankshaft seal leaks.
- Smooth engine operation without shakes, rattles, or unusual noises during idling and test drives.
- Complete service history documentation beyond just CarFax reports.
- Dryness in the passenger rear footwell to rule out leaks from the top, AC, or seals.
- Proper operation of the convertible top, including smooth functionality and no visible wear.
- Cleanliness in the engine bay and overall vehicle condition.
- Exhaust airflow from the outer tail pipes when the dynamic mode is engaged or during revving.
- Louder-than-normal ticking sounds from the engine, which may point to HPFP issues.
- Visible oil puddles, drips under the car, or oil on hoses near the oil cooler.
- Tire condition and door moldings for signs of aging or uneven wear.
### Things I should definitely have the mechanic look for during the PPI that doesn’t require disassembling things
- Signs of oil leaks around the crankshaft pulley, including seepage after running and shutdown, and visible splits in the seal.
- Evidence of timing chain wear, such as unusual noises or rattling.
- Exhaust gases in the cooling system, along with condition of water pumps and valley hose for degradation.
- Suspension components, including bushings and boots, for wear or damage.
- Leaks from AC drains, convertible top seals, or quarter windows, plus rust under the vehicle via a lift.
- Thermostat housing for cracks or signs of failure.
- Operation of exhaust bypass valves by pulling fuse #19 and checking airflow from outer tail pipes.
- Abnormal ticking or loud noises from the HPFP, plus review of oil change intervals.
- Oil cooler and hoses for leaks, cracks, or wear; check for oil in coolant (foaming/discoloration) or coolant in oil (milky appearance); inspect O-rings on adapter.
Old Jul 11, 2025 | 12:39 PM
jahummer's Avatar
@Obtuse1
All of this can be found in the owner's handbook, here and other JLR forums, you've got a '15 so most parts between Jag and Rover are shared as are maintenance parts. Oil changes should be no more than 5K miles or once per year, all fluids including e-diff clutch fluid should follow the handbook schedule and fluid type (engine oil type may be dependent on engine mileage and climate). Cooling circuit flushes haven't been required for a long time with chemistry advances and parts materials engineering.
Swagger XC
XJ XJ12 ( X305 )
Sep 9, 2022 03:56 PM
dtrain
May 22, 2022 04:26 PM
Ken Dreger
Aug 22, 2021 07:02 AM
BoomBoomZ31
Jan 3, 2020 10:03 AM
o1xjr
Australia - Queensland
Mar 16, 2014 05:13 AM
