X150 Fuel Filter
Old Jun 24, 2022 | 09:28 AM
JoeLanger's Avatar
Default X150 Fuel Filter
Hello Folks,
My car went into "reduced performance" mode the other day. the code reader was 0P0087 - Fuel pressure system / system pressure. Error
The breakdown guy suspected fuel filter
After some investigations it turns out the after VIN 32753 models (mines a 2010 40000 something) don't have a remove filter
Can anyone confirm this as true?
I did a search but just lots of people changing the filter itself which is confusing.
So if that is the case, where if the filter? the garage said that jaguar told them the filter is integral to the pump unit ad is for "life"
I'm an engineer and the term "life" really annoys me, life for jaguar is either defined as 3 or 6 years up to 60k miles, at which point they want you to buy a new one
My vehicle has 100k miles and 12 years old, I'd like to actually change the integral fuel filter.
Old Jun 24, 2022 | 10:08 AM
Cee Jay's Avatar
The only filter the 5.0 cars have is the sock on the pickup inside the fuel tank. So, not really a 'filter' per se.
Old Jun 24, 2022 | 10:28 AM
Old Jun 24, 2022 | 11:02 AM
MoXKR's Avatar
Cee Jay, So what is the filter situation on a '09 XKR?
Old Jun 24, 2022 | 11:19 AM
RichardS's Avatar
Originally Posted by JoeLanger
Hello Folks,
I would suspect that a failing pump might be more likely than a blocked filter so you will probably be changing the fuel pump anyway but I would definitely check all the electrical connections first. The garage should be able to check the fuel pressure to be sure that it is really the source of the problem. I don't know about the X150 but the fuel pump itself was certainly a weak point with the X100.
Richard
Old Jun 24, 2022 | 12:03 PM
Cee Jay's Avatar
'09 4.2, or '09 5.0?
4.2 has an in-line filter. GGG probably has a really nice picture of that also, cuz I don't have a 4.2 WSM, just the 5.0 one.
Old Jun 24, 2022 | 01:42 PM
Might as well have details of both 4.2 and 5.0 in the same thread:
Old Jun 24, 2022 | 08:07 PM
V7Sport's Avatar
Easy to replace from under the car. In front of left rear suspension. New filter was about $20 when I replaced mine last Fall.
Old Jun 24, 2022 | 10:55 PM
u102768's Avatar
I would have thought that the pump is more likely but it could be the pressure sensor:
Old Jun 25, 2022 | 02:44 AM
I've added this thread to the FAQ's in a new Section 6. FUEL SYSTEM
https://www.jaguarforums.com/forum/x...enance-227403/
Old Jun 25, 2022 | 11:38 AM
jahummer's Avatar
I had the same thing happen with the Disco last year, same parts as yours. Replaced the rail sensor as that was easy and cheap. New sensor didn't fix the problem so replaced the pump in the tank and problem resolved.
Old Jul 2, 2022 | 01:35 AM
Bill400's Avatar
Default 2010 XK NA fuel filter
My experience with the naturally aspirated 5.0L fuel filter:
Note the cup-like structure shown at the bottom of the flange.
Probably the same part as an XF, although on-line catalog says not.
Verify part numbers as they may be superseded.
The tank flange has an integral filter.
Old Jul 2, 2022 | 06:57 AM
JoeLanger's Avatar
Thanks for all the detailed responses guys. really clears it up
Is it a common modification to add a fuel filter?
Old Jul 2, 2022 | 09:10 AM
jahummer's Avatar
Never heard of anyone doing it as the factory filter’s sufficient, as the last poster said the filter’s built into the removable flange on top of the fuel tank. Here’s a pic of the OEM filter.
Old Jul 2, 2022 | 09:52 AM
JoeLanger's Avatar
erm, this was my original question does it have one of these?
person above says only a sock
Old Jul 2, 2022 | 01:30 PM
jahummer's Avatar
It is indeed a fuel filter, integrated into the fuel tank flange. It’s a serviceable part and has been the subject of multiple recalls over the years for cracking and leaking fuel. The flange/filter connects directly to the in tank LP fuel pump which sits on the bottom of the tank. The fuel pickup has a plastic mesh “sock” which protects the pump from larger particles and the fuel filter further cleans the fuel prior to the fuel lines, injectors, etc.
Old Apr 4, 2024 | 08:06 AM
rsdmitch7's Avatar
V7SPORT; Thanks much for the info. Just ordered part.
rsdmitch7
Old Apr 10, 2024 | 04:13 PM
trkyam's Avatar
My 5.0 XK flange cracked open and leaked nasty yellow stuff from the filter inside the flange.
The reason for cracking most likely is due to high pressure and clogging of the 60 micron filter as well as age of hte plastic.
The flange can be accessed by removing the rear seat (it lifts up) and underneath a rubber grommet, however the bolts
are very hard to get to and may require lowering the fuel tank slightly.
Old Apr 11, 2024 | 08:20 AM
neilr's Avatar
This finally makes sense! You learn something everyday ....
But it is a really expensive way to change a cheap filter
Old Apr 11, 2024 | 09:00 AM
Cee Jay's Avatar
"filter".
More like an old gym sock.
