X150 XKR 5.0sc - pedestrian crash sensor
Old Feb 18, 2024 | 11:09 AM
sam1977's Avatar
Default X150 XKR 5.0sc - pedestrian crash sensor
Evening all
I have ordered a new sensor since the right side one is dead. In terms of fitting I have watched several guides and videos showing how to do this from the top but also a couple of things that say you can't do that on the XKR due to something else being in front of the rad meaning no space. Is this correct? If so what is the best easiest solution - from the bottom removing the undertray? I don't want to remove the whole bumper cover if I can avoid it.
Thanks!
Old Feb 21, 2024 | 09:25 AM
davidedney123's Avatar
Unfortunately you need to remove the bumper to change them on a 5.0 XKR.
You can also use SDD to permanently turn the warning off on the dash once and for all...
Old Feb 26, 2024 | 01:55 PM
sam1977's Avatar
Thank you sir. I thought that might be the answer!!
Our of curiosity when do you see when you look up from underneath with undertray off? I understand when top access wouldn't be available but from underneath is a mystery. Workshop manual does of course say remove bumper.
Thanks again
Old Feb 27, 2024 | 04:26 AM
The horizontal aux radiator is in the way of accessing anything inside the bumper, including the parking sensors.
Old Feb 27, 2024 | 08:39 AM
427MikeB's Avatar
Undertray off & you're presented with this. Left sensor can be seen but not accessed, right side is hidden completely.
charles glass
May 30, 2022 10:27 AM
swdodson
Sep 11, 2018 12:22 PM
DevlinC
Feb 15, 2016 03:22 PM
JAG_XJ
Dec 16, 2015 02:05 PM
