XK Convertible Recall
Old Oct 10, 2013 | 10:41 PM
xjrguy's Avatar
Originally Posted by sharx8
I'm curious, what is the change in functionality? Currently I push the one button to close the roof and keep it pressed to close the windows. Has that changed to a 2 step process? Thanks.
The rub isn't that you might hurt yourself with the top closing, it's that the safety standard states that ANYTHING that CLOSES the side windows, and the top control on the XK does, has to be PULLED away from the panel it's mounted in. That's why you have the window switches that you have to pull up on.
Here's the text from the FMVSS118:
An additional requirement, applicable only to Power-Operated Window (includes vent windows) actuation devices, is as follows (S6c) (Vehicles manufactured before 10/1/2008 need not meet this requirement, but optional early compliance is permitted):
I. Pull Up or Pull Out Test - Any actuation device for closing a power-operated window (regardless of mounting location or meeting paragraph S5 (automatic reversal)) must operate by pulling away from the surface in the vehicle on which the device is mounted. An actuation device must operate only when pulled vertically up (if horizontally mounted), or out (if vertically mounted), or in a direction perpendicular to the surrounding surface if mounted in a sloped orientation, in order to cause the window to move in the closing direction.
Consequently the roof console is changed so it has a switch like the windows. But being above, you push up on it to lower the top & windows, and hook a finger and pull it down to raise the top and windows.
Your Gub'ment at work! Like R_Rated says....... only a Democrat, because they ALWAYS know what's good for you; you're just too stupid to know it! If you don't believe that, just ask one.
My two cents......
Old Oct 13, 2013 | 12:18 AM
ralphwg's Avatar
AARGH!!! Maybe thanks to god that the government is now shutdown.
Old Oct 13, 2013 | 06:13 AM
R_Rated's Avatar
Who decided that needed to be a law? I bet it was a commity of women that we paid to gossip for 4 hours on the click before they took 5 minutes to come up with that.
Old Oct 13, 2013 | 07:39 AM
Quebecjag's Avatar
An additional requirement, applicable only to Power-Operated Window (includes vent windows) actuation devices, is as follows (S6c) (Vehicles manufactured before 10/1/2008 need not meet .....
Well, so it's an USA gouvernement thing, but notice that I think the Republicain were there at that time :-0
PS: I'm canadian and I we do have the same stupidity from our gouvernement whatsoever which party is in place.....
There's just too much red tape!!
vinny jones
Oct 5, 2015 07:20 AM
Foosh
Sep 19, 2015 07:55 PM
Jaguar Forums Editor
Jaguar Press release
Sep 19, 2015 10:18 AM
Tim Goz
Sep 17, 2015 09:11 AM
MediaBobNY
Sep 11, 2015 01:50 AM
