XK (notXKR!) Brake Pad usage.......
Old Nov 16, 2011 | 11:23 AM
britannia's Avatar
Default XK (notXKR!) Brake Pad usage.......
Hi,
Has anyone tried mixing brake pad types. eg. Akebono Ceramics on rear and OEM type on front.
Is this going to work out OK; not sure the ABS will like it or notice ?
Seems to be the only partial solution to brake dust; tried the wax thing (ArmourAll) on the wheels, didn't seem to help much..........
Cheers,
Adrian '07 XK Coupe, 'oo XK8 Conv, '68 E Coupe (just sold, Sadly)
Old Nov 17, 2011 | 06:28 AM
Bruce H.'s Avatar
I would be concerned about affecting the handling by using different pads on just one end of the car. But you could always try the new pad to see if it's better for dust, and then either change the other end also, or go back to the stock pads for both.
Bruce
Old Nov 17, 2011 | 09:38 AM
britannia's Avatar
Bruce,
Thanks for reply.............the reason for asking is I can't find any Ceramic pads for the fronts!
Anyone know if the XK front pads are unique (must be?), I know the rears are the same as the S type and Volvo. Hard to believe that nothing else uses the fronts; very unjaguar, what!
Help! still searching.............haven't looked in the UK yet......
TTFN, Adrian
Old Nov 17, 2011 | 12:22 PM
chazaroo's Avatar
I've also been searching for ceramics but have been unable to find them. If anybody knows who has them please post contact info.
Old Nov 17, 2011 | 12:52 PM
britannia's Avatar
Chazaroo!
Spent a lot of time last nite and this am looking at different brake catalogs and it appears that the 2007 XJ8, S type and XK's have common front and rear brake pads.
If this true then EBC Red Stuff Ceramic pads should fit our XK's , they are not listed for the XK fronts but E35DP1911C fits, XJ8's and S Types!
According to Centrix the same front part nos fit all 3.
And for the rear EBC DP31749C should fit all 3!
Next time I visit Tacoma Jag I will verify if all 3 vehicles are common............
Hope this helps and is true!!
Cheers, Adrian
Old Nov 17, 2011 | 03:13 PM
chazaroo's Avatar
Britannia,
I'll keep my fingers crossed. Let em know it it turns out to be correct info. Thanks!
H20boy
Dec 24, 2024 03:23 PM
perezal
Dec 29, 2015 08:48 PM
ahunt4
Sep 19, 2015 09:49 AM
1964Daimler
Sep 9, 2015 11:28 AM
JagLove86
Sep 6, 2015 10:36 PM
