XK-R and XKRS 2013+ Reliability
Old Apr 21, 2017 | 10:49 PM
XJDanny's Avatar
Originally Posted by kj07xk
Do you know what 'failed' in the active exhaust? Was it the same component each time?
Holy crap! I just googled C2P25629 (the 5.0L version of the back box), and they are reaming you guys! $5200 was the cheapest I saw. When I was looking for the XKR back box for the 4.2L (C2P2176), a year and a half ago, you could get a new one for $1350. Now the cheapest I can find online is $1735. WTF? Inflation in XKR back box spare parts? Sounds like an investment opportunity.
The actuator failed both times. They replaced the rear muffler assembly both times. :-(
Old Apr 22, 2017 | 07:25 AM
jagtoes's Avatar
OK I just looked under the car and see where the vacuum pump is located in the rear left fender well. I also see why they would replace the whole back box as the vacuum actuators are not replaceable. They are welded to the exhaust pipe and the unit is swagged to the bracket. So your options would be to leave the butterfly open , fix it closed or replace the back box. The other method would be to cut/weld a used unit or fit an aftermarket butterfly unit which are available. Interesting as to why they designed it in this fashion. Must have been a cost issue.
Old Apr 22, 2017 | 08:31 AM
Mufc's Avatar
Things that I have fixed or changed since I had my 2012 xkr-s are as follows
1) Air filters were not fitted correctly - torn rubber seal. Replaced with Mahle filters
2) fixed glove box soft open feature- Cord had come off dampner mechanism. Simple fix with removal of glove box, a cotter pin and a 2mm drill bit
3) Fixed dash sound generator - this is the device that makes warning sounds for seat belts, door ajar, turn signal clicks, headlight on warning, ice warning etc etc.
4) oil and filter change with correct Jaguar Castrol Pro oil and Jaguar filter
All very easy to do with basic tools so really two mechanical failure and two service items at 30k miles. Now everything is working as it left the factory.
Old May 29, 2023 | 11:21 AM
devonshire's Avatar
Default jaguar xkrs convertible
Hi, I have just Purchased a 2014 Xkr-s in BRG , Please could anyone help us with the possible build numbers of jaguar 5L V8 XKR-S Convertible in British Racing Green from 2012 to 2014 or even just the total number of convertibles made please.
Old May 29, 2023 | 05:58 PM
ralphwg's Avatar
According to Nigel Thorley's JAGUAR XK/XKR, there were 3984 and 2860 produced in the years as listed. That includes both coupes and convertibles. He doesn't break down as to coupes and convertibles.
Old Jun 4, 2023 | 04:16 PM
JagRag's Avatar
Read these threads...
https://www.jaguarforums.com/forum/x...-163221/page2/
https://www.jaguarforums.com/forum/x...umbers-191901/
https://www.jaguarforums.com/forum/x...egistry-97446/
Old Jun 5, 2023 | 12:42 PM
Barry Leftwich's Avatar
Originally Posted by turbonod
Hello All,
Decided to join to ask you all if you could tell me what the reliability is like for the 2013 to 2015 XKR and XKR-S is like.
I'm wondering if anyone has owned one for quite a bit of time and could tell me if they've had issues with the major components (engine/trans etc) and/or regular maintenance issues.
I do drive a Lexus now and am use to a sense of comfort with its ultra reliable nature but I have been dying to get my hands on an XKR or XKR-S (price permitting).
Obviously, I know its not going to be as reliable as some of the cookie cutter cars, but overall, how does the V8 with a blower stack up? Are they tried and true components used in the past? Any data?
Any info you guys could give me would be greatly appreciated! Thank you!
The water pump goes out shortly after 29,000 miles.If you buy 1 after that amount of mileage,that means somebody fixed it and you won't have any more issues again after that cause I heard once replaced,the part have been revised to fix the problem and idk why they won't just do a recall about it
JACKD
Oct 9, 2020 02:50 AM
uclabrruin1989
Jul 9, 2018 08:39 AM
davidcalgary
Jun 21, 2017 08:56 AM
80sRule
Oct 14, 2015 09:03 PM
