XK window issue
Old Sep 24, 2020 | 11:44 AM
Orv2485's Avatar
Default XK window issue
Hello all,
I'm having an issue with my 2009 XK. Occasionally when raising my passenger side window, it comes up about about 4" the goes back down. Since I have owned it (1 year) it's made a noise at that point like it is skipping a tooth on the drive.
Thanks in advance for any help.
Tom
Old Sep 26, 2020 | 02:57 PM
Welcome to the forums Tom,
Each door window has an anti-trap safety feature. If the upward movement of the window detects an obstacle, the anti-trap detection system immediately stops the window closing and then moves it downwards for a short distance. The anti-trap protection also stops the window closing if a blockage or resistance occurs (e.g. in the window guide channels). Typically this might be due to icing in winter but can also be caused by damage or misalignment of the guide channels or seals. Check the channels are clear and the glass moves smoothly on opening or closing.
If it persists and you need to check if there is a problem with the motor (2) or regulator (1), the door card will have to be removed.
Old Sep 26, 2020 | 03:00 PM
MarkyUK's Avatar
does it close when you use autoclosure when locking the car?
Old Sep 26, 2020 | 03:13 PM
Stuart S's Avatar
The first thing to try is resetting the windows. If it fixes your problem, you got lucky! It's quick and easy.
Old Sep 26, 2020 | 05:40 PM
George05's Avatar
Also check the fuses
Old Sep 26, 2020 | 07:12 PM
Orv2485's Avatar
Didn’t know about the autoclosure feature. I will have to read up in the manual. The problem is intermittent though.
thanks
Old Sep 26, 2020 | 07:13 PM
Orv2485's Avatar
I will give that a try, thanks for the suggestion
Old Sep 26, 2020 | 07:17 PM
Orv2485's Avatar
I will take a look at the track, hoping it is something simple as that
Seil39
Nov 8, 2019 07:37 PM
phillip.blaha
Nov 3, 2016 07:03 AM
Darve62
Sep 8, 2014 09:17 AM
keywasted
Jul 14, 2011 02:05 AM
