XK / XKR License Plate Lamp plastic frame issue?
Old Jul 14, 2015 | 05:52 PM
whostorm05's Avatar
Question XK / XKR License Plate Lamp plastic holder issue?
So after a drive the other day I noticed my driver side license plate light frame was dangling from my trunk lid. It appears a plastic tab broke off the frame. I bought what I thought was the correct replacement - part number C2P11429 - but this one doesn't have a tab and instead has what appears to be a screw hole to screw it into the gray trim piece. My gray trim piece has nowhere to screw it onto. I'm guessing later models screw onto the trim piece because this tab kept breaking. Anyone with an XK/XKR mind checking out theirs and telling me what yours looks like? I'm trying to figure out if there's a way I could get the new one to work without replacing the gray trim piece. If anyone has any alternative suggestions to get either my old part or new part to stay in place I'm all ears. I can't get the passenger sold one to come off to see what it looks like and I'm afraid if I force it I will break the tab and make my bad situation worse.
I'm attaching a pic of the old and new parts. The old one is up top and you can see the broken tab to the right.
Attached Thumbnails XK / XKR License Plate Lamp plastic frame issue?-20150714_184751.jpg
Old Jul 14, 2015 | 05:57 PM
whostorm05's Avatar
Forgot to mention that the car is a 2008 XKR.
Old Jul 15, 2015 | 08:30 AM
whostorm05's Avatar
So I'm now learning that the part number I ordered is not correct. I've asked the eBay seller for the correct part number. The auction clearly states this is for a 07-11 XKR so I don't know where I went wrong. I'm hopeful they can provide me the correct part number and that I will be able to find it. They do not stock it.
This is the one I wrong one which i purchased:
Jaguar 07 11 XKR License Lamps Rear Lamps License Lamp Left C2P11429 | eBay
Old Jul 15, 2015 | 08:33 AM
whostorm05's Avatar
The new part number they are suggesting I need is C2P3668. I may run by the local Jag dealer and verify. When I called the local jag dealer they said they wanted 60+ dollars for the part but I forgot to ask for the part number.
Old Jul 15, 2015 | 08:40 AM
WhiteXKR's Avatar
Ebay listings often contain errors. Use an online parts dealer. Your dealer is charging double list price. Send them your VIN and they will verify compatibility.
For example:
LAMP-NUMBER PLAT | Genuine Jaguar | C2P3668
LICENSE LAMP | Genuine Jaguar | C2P11429
Old Jul 15, 2015 | 10:04 AM
whostorm05's Avatar
Yeah, should have used my VIN to begin with but couldn't find a good part lookup place. Oh well. Just purchased a C2P3668 off ebay. Anyone have a need for a C2P11429?
Old Jul 15, 2015 | 11:59 AM
whostorm05's Avatar
I like how the Gaudin site still says C2P11429 would fit a 2008 XKR. I wonder if it switched mid model year or something. What crap....
Old Sep 16, 2015 | 12:04 PM
ag986's Avatar
I have the same problem on a 2010 XK, but for the light on the right-hand side of the plate. Does anyone have the correct part number for that? I have an unused C2P11428.
Thanks,
Old Sep 20, 2015 | 10:39 AM
ag986's Avatar
Thanks,
I've found the answer to my question: C2P3667
Old May 11, 2016 | 04:28 PM
whostorm05's Avatar
So the driver side replacement just broke. Same tab broke. I'm assuming this is the reason why they switched to the screw in type. So annoying. It didn't even last a year. I'm guessing there's no warranty on this either as I bought it off ebay. Ugh.
Old Jan 8, 2019 | 01:14 PM
DannyJ's Avatar
How do you remove the rear plate lamp housing on a 2008 XK ?
Can't find it in the workshop manual and it is too fragile for a mistake...
thanks
Old Jan 8, 2019 | 01:51 PM
TexasTraveler's Avatar
thanks
Page 2469 of workshop manual shows the 4 bolts that need to be removed, 2 behind the small plastic circles and 2 behind the lights... There should be some double-stick tape holding it on as well towards the ends of the finisher...
Old Jan 8, 2019 | 02:51 PM
DannyJ's Avatar
"2 behind the lights..."
My question is how to remove those 2 lights
Old Jan 8, 2019 | 03:19 PM
The lights simple pop out on one side using a small flat head screw driver or a pick... I believe the side that pops out will be towards the middle of the car on both lights...
Old Jan 8, 2019 | 03:33 PM
DannyJ's Avatar
thank you TexasTraveler
toronadomike
Jan 22, 2026 10:13 PM
PMKimpton
Aug 3, 2019 08:22 PM
Beardy
Sep 18, 2015 10:00 AM
obwoodie
Sep 3, 2015 07:45 PM
Dallas XK8
Sep 3, 2015 12:17 PM
