Xkr 5.0 Oil level difference cold vs hot
Old Feb 27, 2025 | 11:12 PM
Street cat's Avatar
Default Xkr 5.0 Oil level difference cold vs hot
How much oil level variance are you all seeing on 5.0 xkr?
for example, when i measure hot (right after shutting down the car) it’s telling me to add 1qt/.5qt
When I measure cold (after sitting for 1hr) it’s showing full
Old Feb 28, 2025 | 03:09 AM
OzXFR's Avatar
It's the same on all modern Jags with the electronic oil level read-out, 5.0 SC included.
Straight after shutdown the engine has heaps of oil (my best guess around 1.5 litres) in the various oil galleries and all that oil takes a while to drain back down into the sump where the oil level is measured.
That's why the Owner Manual/Handbook says to wait 10 minutes after shutdown before attempting to bring up an oil level read-out, and if you try to access the read-out before 10 minutes have elapsed you get the message "unavailable refer to handbook". Obviously you have figured out that you can get a "hot" oil level read-out by popping the hood/bonnet.
I for one don't bother faffing about waiting 10 minutes, instead I always check the oil level first thing in the morning with a dead cold engine and it's never failed me yet!
Old Feb 28, 2025 | 08:47 AM
Street cat's Avatar
thanks!
I did notice the oil level meter change a bit when measuring hot (indicating 1qt low, then .5qt low) , so exactly as you say, oil draining back into the pan.
Old Feb 28, 2025 | 11:20 AM
Stuart S's Avatar
When in doubt
Street cat
Dec 9, 2025 09:58 AM
Randy Carlson
Mar 14, 2023 04:14 PM
indietor
Mar 17, 2018 06:29 PM
jagtoes
Aug 23, 2016 12:44 PM
funkdoktor
Dec 8, 2011 08:34 AM
