XKR convertible rear qtr light windows
Old May 25, 2015 | 04:11 PM
Jaggy Pat's Avatar
Default XKR convertible rear qtr light windows
Bought my XKR last June and always thought there was a little more road noise from the passengers side than from the drivers side, asked the Aberdeen dealer to check the passenger window out when it was in for a separate warranty issue. They reported nothing wrong but could replace all the roof seals for around £600+!!
Fitted the Jag Wrangler kit and I can now close the rear quarter lights with the roof down and I notice that the rear passenger quarter light 4window stops short (about 5mm) of aligning with the passenger door winkdow, and the seal is fixed to the quarter light so it will never fully engage with the roof when the roof is up and thus I assume is the source of the apparent road noise! So I have already reset the all the windows when I installed the roof kit is there another technique for resetting them manually, say when the roof is down so I can see that the window goes fully up! Appreciate any help on this!
Footnote - the noise was apparent before fitting the Jag Wrangler roof kit so the fitting of the kit has nothing to do with but it has allowed me to see where the problem is.
Old May 25, 2015 | 04:32 PM
WhiteXKR's Avatar
The rear quarter window position can be adjusted, but you will need to remove the interior quarter trim, which is a bit tricky, to get to the adjusting bolts.
Old May 25, 2015 | 04:42 PM
Jaggy Pat's Avatar
Thanks mate, There is a link to a workshop manual in here somewhere so I will download it and reset the windows.
niner nellie
Sep 1, 2015 10:53 PM
tonydbaker
Aug 30, 2015 11:02 PM
peterg19
Aug 28, 2015 08:42 AM
MrNobody
Aug 27, 2015 07:49 PM
divingmom
Aug 25, 2015 07:54 PM
