XKR Problem
Old Aug 25, 2019 | 02:42 AM
Gilch 66's Avatar
Default XKR Problem
Hello together from Germany. I have the problem that my air mass meter bank B has displayed incorrect values ​​for the intake air temperature. I have replaced it with an accessory spare part now I have the error message system too lean. You should always replace both sides with identical. I checked for false air and did a hard reset all without success. XKR 2008 SC Thanks for your help
Old Aug 25, 2019 | 10:16 AM
Ngarara's Avatar
What diagnostic codes was it showing before, and what codes now?
Old Aug 25, 2019 | 11:24 AM
Cee Jay's Avatar
Is it SYSTEM too lean, or bank 1, or bank 2, or bank 1 & 2? You may have inadvertently created a vacuum leak. Did you recheck your work? Maybe a loose/disconnected vacuum line.
Old Aug 25, 2019 | 12:45 PM
Gilch 66's Avatar
Hello. The error code with the old air mass meter was P0110 with the new one I have the error codes P0171 and P0174 on false air I checked, found nothing but as I said the new air mass meter is from a different manufacturer than the original. Could that be the cause of the new error codes ,
Old Aug 25, 2019 | 01:32 PM
JagV8's Avatar
A MAF that reads wrongly can cause those codes, yes.
You could check fuel trims as often posted but if the MAF is wrong then the readings will be bad of course, whether there's a leak or not.
GWS
Sep 26, 2020 05:43 PM
BahamaJim
Apr 2, 2018 07:43 AM
leadpusher
Jun 29, 2014 09:46 AM
Mendo XK
Apr 7, 2013 07:14 PM
User 070620
Jan 31, 2013 11:55 PM
