XKR vs XKR Dynamic Pack
Old Nov 6, 2020 | 04:35 PM
tmich's Avatar
Driver/Soft is in a differential or it is in one of "main" computers? If I retrofit a differential from XKRS would it affect a software of my car will be still using an old software (XKR, as build)?
Old Nov 6, 2020 | 04:45 PM
Cambo's Avatar
The differential assembly, and the software in the diff control module, are the same between XKR & XKR-S.
Old Nov 6, 2020 | 05:01 PM
tmich's Avatar
Okay, so no point in doing this "change".
Having you there - I know you have changed your vertical links/knuckles for the forged ones (XKRS).
Do you have any idea if XFRS can be a donor of a front vertical link for a X150? They have a slightly different wheel hub (the way how it is mounted in the knuckle) vs X150. Dimensions seems to be the same (mounting point, as a knuckle is a bit bigger). ABS cable connector looks the same etc.
Old Nov 7, 2020 | 02:45 AM
Marcin Wasilewski's Avatar
Tmich - you live in Poland, right. Can you in touch with me 889150000 I have a 2010 XKR and have one question. Z gory dziękuje Marcin
multistrada74
Apr 14, 2025 09:32 AM
Grimreaper
Mar 28, 2018 11:30 AM
AlexJag
Jan 14, 2017 03:26 PM
Ngarara
Aug 2, 2014 06:53 PM
samy
Jun 6, 2013 11:36 AM
