xkr wont start
Old Feb 20, 2018 | 09:07 AM
Huff's Avatar
Default xkr wont start
2014 XKR wont start with charged battery, thought maybe smartkey battery and changed also, still dead.
At first I had lights then charged battery full, now nothing.
Old Feb 20, 2018 | 09:14 AM
jagtoes's Avatar
OK what is the voltage at the battery. Is it 12.6V or better. If so do a reset by removing the positive and negative terminals from the battery and then touch them together for 10-20 seconds. Then reattach and see what you have. Also how did you charge the battery and with what type of charger.
Old Feb 20, 2018 | 09:36 AM
myexcursion's Avatar
does it crank or getting no response at all when pressing start ?
Old Feb 20, 2018 | 11:28 AM
kj07xk's Avatar
If you pumped the brakes trying to start it, you may have pressure already in the brake lines, so try 'standing' on the brake pedal while holding down the 'start' button. I mean it, really put your foot into that brake pedal.
Old Feb 20, 2018 | 11:36 AM
Ranchero50's Avatar
Define what's wrong with it better. Does the interior lamps light up when you open the door? If yes, does anything light up when you hit the start button?
WAG says loose battery terminals but don't have enough info to go off of.
Really need some details. I'm about 40 minutes away if you really need help with it.
Old Feb 20, 2018 | 01:17 PM
Originally Posted by Ranchero50
..... I'm about 40 minutes away if you really need help with it.
There's an offer I've rarely seen on the forum.
ALLEN68
Oct 30, 2023 02:11 PM
dchristy
Aug 22, 2022 11:29 AM
dharidas1477
May 17, 2017 12:22 PM
Dave Baumgartner
Mar 30, 2017 11:12 AM
LedZepplin
Nov 19, 2015 08:58 PM
