ZF 6HP28 filler plug size and access
Old Mar 27, 2021 | 06:00 AM
bigbaddog's Avatar
Default ZF 6HP28 filler plug size and access
Does anyone know the correct size hex bit for the filler plus on the above gearbox? Is access tight? I do have some shallow access hex sockets and ratchets (snap on)- will these work?
Old Mar 27, 2021 | 03:12 PM
Sean W's Avatar
a pic of what you have would help. It's an 8mm hex head - torque is 35 nm when you get done. I use a 3/4" long piece of an Allen wrench through an open ended ratchet wrench. Yes access is very tight but obviously can be done:-)
Old Mar 27, 2021 | 04:05 PM
bigbaddog's Avatar
thanks- your measurements and suggested technique is really helpful.
Old Mar 29, 2021 | 02:18 AM
No Quarter's Avatar
Access is tight and it has to be done with engine running=hot exhaust. Still have a scar on my arm. I recommend those thermo-protection sleaves
xjay8
Apr 29, 2015 02:38 AM
JagScott
Jan 23, 2014 02:36 AM
Xjs 1980
Nov 17, 2013 04:04 PM
azeteg
General Tech Help
Jul 19, 2013 05:30 AM
1988xj6navy
XJ40 ( XJ81 )
Jun 20, 2009 09:02 PM
