XK120 XK140 XK150 1948 - 1962
Girling Brake Fluid : XK150
Old Apr 27, 2014 | 04:56 PM
SSMcDonald's Avatar
Default Girling Brake Fluid : XK150
What specific brake fluid takes the place of Girling Brake Fluid?
Old May 1, 2014 | 02:57 AM
jaguar38s's Avatar
hello,
Any DOT 3 or DOT 4 specs Brake Fluid will be a good replacement.
Regards,
Peter Jan ( Xk150, 3.8 S-type )
Old Jun 19, 2014 | 11:41 AM
Nick 53 120 OTS SE's Avatar
Default brake fluid
as said, any Dot 3 or 4, standard or HD, but NOT silicone. Castrol GT LMA is always a good choice. Brake fluid absorps moisture from the air, so use fresh fluid always, tightly seal any container. Brake fluid spills bubbles paint !! Always protect fender paint with a vinyl topped fender mat or similar and use extreme care. Fanatics flush/replace fluid every so often..year or two or three..fearing water in the fluid, which will corrode wheel cylinders etc unless they have been replaced with stainless or similar. The proximit of the master cyl to exhaust can heat the m/cyl and fluid, so the higher temp rated fluids are a good idea. (thus also a heat shield on the xk120/tandem.)
Dimitrigregorio
17
Sep 5, 2019 03:47 AM
picard
Oct 12, 2015 11:56 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
Richard_gib
Sep 12, 2015 07:08 PM
trebor12
UK & Eire
Sep 12, 2015 12:21 PM
