XK120 XK140 XK150 1948 - 1962
Timing chain tensioner on XK140 engine
Old Jun 27, 2016 | 04:12 AM
rmsarch's Avatar
Thumbs down Timing chain tensioner on XK140 engine
I am rebuilding a 1956 Jaguar XK140 engine and have a new ROLON hydraulic chain tensioner for the lower timing chain. Ken Jenkins of the Jaguar Enthusiasts Club assures me it is the right product. Together with the body, it consists of the circular plunger with a chamfered rubber end piece, a spring and (at the inner end of the spring) a circular hollow tube with an angled, serrated slot.
The serrated slot allows the unit to be locked up tight by compressing the spring and rotating the end piece.
In order to fit the unit against the lower timing chain, it is necessary to first release the spring (because you cannot release the spring after the unit is bolted onto the engine) but I find that the circular plunger does not have a full free travel but seems to snag on the serrated plate. What am I not doing?
Old Jun 27, 2016 | 08:03 AM
Jagfixer's Avatar
Or you checking with it mounted? Doesn't travel right unless mounted.
Old Jun 28, 2016 | 06:27 AM
rmsarch's Avatar
Yes I have fitted it but it seems reluctant to move in and out on the spring.
Old Jun 30, 2016 | 07:23 AM
jaguar38s's Avatar
Hello,
I used the same tensioner as you did.
Rebuild the motor last month, and it seems to work fine.
And indeed you can't fit it with the nylon piece in place.
So I kept it compressed by hand while fitting it.
you can only mount it one way, or the plunger gets stuck on the plate.
Seems you have it the wrong way then.
regards,
Peter Jan
revski666
Mar 23, 2026 04:06 PM
kenneyk843
Nov 12, 2021 07:50 AM
tai4de2
Apr 5, 2016 02:56 PM
Andi Allko
Apr 4, 2016 04:06 PM
kenatofc
Apr 3, 2016 10:42 AM
