XK120 XK140 XK150 1948 - 1962
XK 120 Battery / Voltage Questions
Old Jan 13, 2024 | 03:20 PM
SFRoBo's Avatar
Smile XK 120 Battery / Voltage Questions
(I think this is what the forum is requesting.)
Just won a BAT auction for a 1953 running, drive-able XK-120 roadster. I'm 85 years old, and have been involved with autos all my life, but this is my first "historic" car. The WSJ, many years ago, said folks like me want cars that they envied when teenagers but couldn't afford at the time. The XK-120 fits the description! I always envied the 120 with wire wheels, but I settled for discs, and have been advised that wire wheels come with maintenance issues.
I don't plan to restore, but just bring it up to a reliable vehicle for regular use, about which I won't worry when I park it. I will leave restoration to my co-owner-son, who will inherit it. I look forward to learning what I need to know from other forum members. I've asked a local Jaguar shop to provide an assessment and recommendations.
One question that comes to mind relates to the battery. There is one, 6V battery in place, in one of two battery boxes behind the seats, said to be positive ground. Should I add a second, to be wired in parallel, or is it customary to rely on just one battery? The agent for the seller suggested converting to 12V, negative ground. What components, other than bulbs, are polarity-sensitive or voltage sensitive, that would have to be replaced or modified?
Thanks.
SFRobo
Old Jan 14, 2024 | 09:21 AM
BruceH's Avatar
Default Wheels
When I was 85 (two years ago) I got an XKI-140 FHC with wires. The adapter hubs have been a real pain to work with/replace. Consider yourself lucky with the disk wheels. At the time, I felt that the Jags of friends drove like pickup trucks. I still feel that way - there is a reason for the steering wheel being so large in diameter ! But they do look great. Enjoy !
Thanks.
SFRobo
When I was 85 I got an XK-140 FHC with wires. Those hub adapters with tired old splines have been a nightmare. Consider yourself lucky to have the steel disks. When I drove XKs of friends while in college I criticized the cars that I couldn't afford for driving like a truck. There is a reason why the steering wheels are so large in diameter. But the sure look gorgeous !
Have fun
Old Jan 15, 2024 | 06:24 PM
Fraser Mitchell's Avatar
Thanks.
SFRobo
It is a 12v system so won't work with just 6 volts. Are you sure it isn't just a compact 12v battery ?
Old Jan 18, 2024 | 07:32 PM
Bill Mac's Avatar
The XK120 originally had two 6-volt batteries wired in series for 12 volts.
If the car is currently running as Fraser says it may be on just one compact 12-volt battery in place of the two 6-volt batteries.
Those earl circa 1950 batteries were quite inefficient and very bulky compared to modern batteries.
Conversion from positive earth to negative earth is quite simple on these early model Jags. I have done it many times on my own cars as well as friends' cars.
The battery connection needs to be reversed.
The generator fields need to be re-flashed to the desired polarity.
The ammeter leads need to be reversed.
You need to check the fuel pump. Very early SUs were not polarity sensitive but later ones have a diode which needs reversing and the latest models using hall effect have to be changed.
You DO NOT need to change anything in the ignition system if it is still standard, general lighting and things like windscreen wiper motors.
VinceCh
Jul 6, 2023 10:15 AM
Car Crazy
Oct 26, 2019 06:55 AM
Rey
Jul 28, 2017 07:55 AM
nujagowner
Jan 31, 2015 01:28 PM
sjtyrer
Sep 9, 2013 03:40 PM
