XK120 XK140 XK150 1948 - 1962
View Poll Results: Was this issue well described?
Have you had a similar issue?
0%
Is this issue another quirky British automotive problem?
0%
Voters: 0. You may not vote on this poll
XK 150 DHC convertible top latches
Old Sep 21, 2021 | 09:35 AM
Paul Apostolou's Avatar
Default XK 150 DHC convertible top latches
Hello my name is Paul Apostolou and I reside in Pittsbrugh.
I have an XK150 DHC that is pretty much a survivor. The original top and headliner have resided under the boot cover for the last 40 years.
It still appears to fit but the latches that secure the front to the windscreen top won’t stay attached. They keep popping open. Is this a common problem and if so
is there a solution. I would purchase new latches if I felt that was the solution but the latch hardware on the windscreen frame and the latches them selves
appear to be fine. I’ve reconditioned the top to alleviate any shrinkage. Comments and suggestions are greatly appreciated.
Old Sep 21, 2021 | 01:30 PM
Fraser Mitchell's Avatar
My thought was that there must be a compressible rubber seal where the front of the top (UK=hood),sits on the windscreen frame. If this seal has "sacked-out", or is missing, there won't be any tension on the securing clips, so they wil not stay latched. The latches are of the "over-centre" type that rely on something, (which can only be a seal, the latch has no spring), to provide upward pressure on the latch where it's secured to the hook on the windscreen frame.
Old Sep 21, 2021 | 02:30 PM
Thanks Fraser your theory sounds entirely plausible. The seal is almost non-existent. I’m going to simulate the seal with some compressible rubber
that I have available and see if that works. In the meantime I’ll order a new seal.Paul
myjag
Jul 15, 2020 04:30 AM
khsjsilver
Aug 8, 2017 01:26 PM
lunaticpro
Jul 17, 2017 03:23 PM
Francophile
Jun 17, 2017 03:41 AM
