XK120 XK140 XK150 1948 - 1962
Xk120 Fuel pump
Old May 30, 2015 | 08:58 PM
georgeryoung's Avatar
Default Xk120 Fuel pump
My third fuel pump (during 35 year ownership) is required for my xk120. I'm wondering if I should investigate an electronic fuel pump or go with the OEM/
I'm +ground and wish to keep it stock. I'd appreciate any advice from folks that have had the same issues. thanks
Old Jun 5, 2015 | 04:15 PM
Fraser Mitchell's Avatar
Three pumps in 35 years doesn't sound bad, but if its Pump 1 lasted 33 years and Pumps 2 & 3 were needed in years 34-35, there is a problem ! First step is surely to flus out the fuel tank. Second thing is what petrol are you using and how many miles are being run per year. Too much ethanol in the petrol may be affecting the pump diaphragm. What pumps are you fitting ? The originals are still made and electronic versions are available : -
SU Fuel Pumps & Spares - SU Carburetters
Old Jun 16, 2015 | 12:00 PM
LouieXK's Avatar
I like to keep the original setup if all the plumbing is in place -- there are rebuild kits for the SU pump, it also may be possible to replace just the pump portion, and not the 'head'
On my 120, that came without the original plumbing, I am using a Facet pump, made out of resin/plastic, so no grounding issues. Bought at NAPA, but I have seen them on ebay at a reasonable price.
Be sure and have at least one see-thru fuel filter before the pump.
Old Jun 23, 2015 | 09:28 AM
christianbrustlein's Avatar
Replaced mine on XK140 with SU, after one year, humidity and water destroyed it. Since then installed a Facet and No problem what so ever ! Cheaper and much better quality, apparently.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
JWheeler
Nov 22, 2019 08:28 AM
ccfulton
Sep 20, 2015 05:15 PM
Sprayall
Sep 3, 2015 07:49 PM
