‘97 xk8 battery
Old Jun 23, 2024 | 05:18 PM
Rosevillesister's Avatar
Default ‘97 xk8 battery
I’ve seen various posts about batteries, good/bad/checking voltage..etc. Here’s my recent issue with my ‘97 xk8(74K miles); turned on the a/c and shortly noticed the battery gauge dropped a bit. Highway driving , 70-75mph. Turned off a/c, gauge went right back to perfect. I keep a close eye on all those quirky gauges, so this was a first. No issues at all with anything else. I don’t have access to the service records right now, but I do remember that the battery has been changed( number of times tbd). Off the top of your exceedingly clever heads, any tips, suggestions, advice? I may have a new mechanic on the horizon and hope to ask him questions and/or anticipate possible problems. As usual, likely overthinking this…Thank you!!
Old Jun 23, 2024 | 05:48 PM
michaelh's Avatar
When the A/C is engaged, both of the cooling fans are running at max. They draw a relatively large amount of power in this mode so it may just be that which is dropping the battery voltage a little.
If you're not having any other issues then I'd just make a note. "Keep calm and carry on", they say.
Old Jun 23, 2024 | 06:57 PM
So right… li need to literally have that on post-its in every corner and that includes the car. Thank you for the reassurance! In another car, I had the alternator fail twice… a most unpleasant experience.
Old Jun 24, 2024 | 02:11 AM
Pistnbroke's Avatar
The voltmeter is a fake gauge ..it has 3 computer controlled positions ...in the centre ..computer thinks all is well. Hard to the left ..not charging .. Hard right overcharging.
So you is OK
Old Jun 24, 2024 | 08:40 AM
Jon89's Avatar
Your battery should have a sticker somewhere on its casing showing a four-digit code. The first two digits are the month and the last two digits are the year that your battery was manufactured....
Old Jun 24, 2024 | 10:59 AM
So you is OK
Those gauges are nuts. I read a bit about them when I first looked at the car. They’re either fine with some leeway….or not so fine. Jaguar designers were having a bit of a laugh at paranoid folk.
Thank you!!
Doc Oc
Jan 26, 2026 08:41 PM
cobratom
Dec 11, 2017 10:54 AM
CRHINO
Oct 23, 2017 01:46 PM
mick99
Sep 24, 2011 07:50 AM
brgjag
May 13, 2010 07:20 PM
