'01 XK8 Rear Shocks
Old Jan 15, 2019 | 02:49 PM
srpope80's Avatar
Default '01 XK8 Rear Shocks
What's the consensus when it comes to replacing the rear shocks on a 2001 XK8? Just replace the shocks, 2 washers and 2 isolators that come with the shock assembly (Bilstein), or are there any other parts recommended to replace "while you're in there"?
Thank you!
Old Jan 15, 2019 | 04:07 PM
Johnken's Avatar
Srpope, good question.
I was lucky the 1st time I changed my front shocks, already bought the upper mount, and I didn't trash the plastic spring centering device. It sure would be a headache if you found a need for worn or failed parts in the middle of the job. Odds are the part is several days away in a different state.
I've got to replace my rears too, so I will be watching your question.
BTW, is around $200 the best price range you've found for identical Bilstiens?
thanks,
John
Old Jan 15, 2019 | 04:33 PM
1LeSvT's Avatar
I would replace the Spring Isolators too, P/N: MMD3565AA
Old Jan 15, 2019 | 06:22 PM
srpope80's Avatar
thanks,
John
i was able to get Bilsteins for 98/ea. Plus shipping, and I agree I’d rather be prepared for 20 year old suspension gremlins!
Thank you 1LeSvT, I thought that seemed to be the upper wear bushing for the cap but couldn’t tell. I appreciate it.
I’ll post my usual pictures and write up as I tackle the job.
Old Jan 15, 2019 | 07:05 PM
michaelh's Avatar
Not really to do with the shocks, but you might take a look at the nearby rear roll/sway bar bushings and drop links while you're in there, if you haven't already...
Old Jan 15, 2019 | 07:11 PM
srpope80's Avatar
Thanks Michaelh, definitely plan on that as well! This is the new craigslist find so everything is under inspection and scrutiny. I appreciate all of the advice for jobs I’ve yet to do.
Old Jan 15, 2019 | 10:15 PM
Johnken's Avatar
+1 on Michael's suggestion. Srpope, you'll be amazed at what an improvement the rear BBC sway bush changes do make.
John
Choptank
Dec 8, 2015 07:50 AM
ehaglund
Oct 18, 2012 11:29 AM
rocklandjag
Jun 11, 2011 11:42 PM
mmolaik
Sep 21, 2010 02:44 AM
McJaguar
Oct 1, 2008 10:51 AM
