A 2006 bumper on a 2000 jag xk8
Old Nov 18, 2018 | 10:16 PM
Jagxk8isaac's Avatar
Default A 2006 bumper on a 2000 jag xk8
I just wanted to know if it is possible to put a 2006 xk8 bumper on a 2000 xk8 thank you
Old Nov 19, 2018 | 09:31 AM
Welcome to the forum Jagxk8isaac,
As I have read reports of early 4.0 litre models being updated to the later 4.2 litre appearance with bumpers and lower side mouldings, it must be possible. Whether it is a direct replacement without any modification being required is another matter but the rear and side fixings are the same so you could be lucky.
Old Nov 20, 2018 | 12:38 PM
ccfulton's Avatar
The bumper will bolt up but you will also need the fender well liners from the newer car as they are a slightly different shape.
For the side sill covers, the OEM installation method requires drilling some holes in the rocker panel for mounting them. I did not like that idea so much.
There is a thread or two on here about how to do it.
Old Nov 20, 2018 | 02:30 PM
woox4's Avatar
Different undertray too I believe.
Old Jan 13, 2019 | 11:26 AM
bcprice36's Avatar
Jagxk8isaac....
Sorry I missed this back in November..
All these answers are correct but where the holes have to be drilled, remember that all 2005 & 2006 XK8 & XKR's have these same holes....as they came with the same Rocker Panels and after 14 years, I don't see any problems with the Drilled Holes.....
What you need is to find a 2005 or 2006 that has been hit in the Boot.....Buy the entire Front Bumper, Grill, Lights, the Under tray, Fender Liners and Rocker Panels.....Then your 2000 XK8 will look like a 2005-2006...a Couple/Three Thousand Dollars later...….but it will still be a 2000!
Billy Clyde
Old Jan 16, 2019 | 04:15 AM
MediaBobNY's Avatar
.. and as far as I know, the rear bumper was also restyled in a minor way at some point - probably on the '05's/'06's. Also, as an f.y.i., the side rocker panels on the newer models are simply snap on / snap off.
hunterpedigo
Jun 21, 2017 08:59 PM
Rainier
Sep 9, 2013 02:05 PM
JgaXkr
Sep 2, 2013 08:32 AM
r0m8470
Jun 11, 2012 11:38 AM
Innovative Detailing
Detailing / Car care
Jan 24, 2012 12:31 AM
