01 XKR xenon headlight availability?
Old Mar 4, 2024 | 04:40 PM
extheaterkid's Avatar
Default 01 XKR xenon headlight availability?
Hello everyone, hoping you can help out with a question?
I am in the process of finally moving forward with my 06 coupe restoration project and I am stuck on finding a Drivers xenon headlight assembly. The cheapest one currently available is over $800 shipped. While not completely unreasonable, that's still more than liked.
So the question, I have found an 01 XKR parts car available. Is is possible that it came with xenons as standard or an option? The preference is standard as that takes some of the question out of it.
I ask as the seller has been a bit flakey, doesn't want to pull it to check (until he sees cash which is valid given the fiddly nature of it) and the car is a fair drive away. The drive is worth it for the price but not if they are the standard halogen units.
Thanks y'all!
Old Mar 4, 2024 | 04:57 PM
motorcarman's Avatar
I only know North American Jaguars but I don't remember performing a PDI or working on an X100 with HID headlamps until the 2003MY (4.2 liter) when I worked at the dealer back then.
Old Mar 4, 2024 | 05:24 PM
Motorcar, appreciate the reply. USDM is my market as well so that where the hope came from. If 03 is the breakover, I'll start looking there.
Quick question, my assumption is that the obvious tell without seeing the bottom or back of the unit is the black interior on the lens, correct? I have only seen ones with the silver interior after its been swapped for repair.
Old Mar 4, 2024 | 08:27 PM
giandanielxk8's Avatar
As far as I know, the HID were standard in the 4.2 XKR (2003 and up), but optional in the 4.0 cars. Now what exactly is wrong with your coupe's headlights?
Old Mar 5, 2024 | 09:31 AM
The North American JEPC for cars to> VIN A30644 shows HEADLAMP ASSY., EXCEPT HEADLAMP LEVELING.
Powerwash and EXCEPT powerwash are the only options available.
HEADLAMP ASSY - H.I.D. is only available FROM VIN A30645> as an option.
Old Mar 7, 2024 | 01:24 PM
@giandanielxk8 @motorcarman Thank you both for the assist on this! To answer the question on whats wrong, minor fender bender damaged the black plastic rear assembly to a point that it's not repairable. I've been searching for either a parts unit that I can swap the working pieces into or a complete unit that saves that hassle.
firstgareth
Jul 14, 2023 07:18 PM
Phogstr
US Lower Atlantic
Dec 7, 2017 07:00 PM
JagRag
Sep 10, 2017 07:42 PM
Jackemail
Nov 10, 2014 04:12 PM
cadmium
Apr 29, 2012 04:43 PM
