Curve in the front coil spring.
Old Mar 7, 2024 | 11:34 AM
cjd777's Avatar
Default Curve in the front coil spring.
Being a WHY kind of guy, I'm a little bit annoyed after installing new mounts, bellows, bump stop and shocks. The spring has a slight curve on one side.
After taking things apart with a VEVOR strut compressor, (easier than rods for that part) but installed with rod spring compressors for controlled release.
I ended up with both springs having a bit of sideways bulge.
I do remember on a longer spring having this happen but not on these Jaguar one.
Couple of things I ran into. One the bellows gaiters were the same number from NAPA) but were of different materials, they installed by stretching the rubber around the bottom part of the bell, fine, but one was rubber flexible and the other a more of a PVC, which needed heating to get around there. Same number.
I do like the way it covered the stem for a dust cover.
Just a word to the wise of things that go wrong with this little simple job.
Old Mar 7, 2024 | 12:06 PM
Jon89's Avatar
Wayne,
Are you doing this job on your own 2000 XK8 right now? I was supposed to be there to assist you! I'm guessing that Alan is in town and you guys are going at it....
Old Mar 7, 2024 | 02:35 PM
cjd777's Avatar
No Jon, Ken out of Chattanooga dropped his off as units. The spring compressors were not to his liking. Really don't blame him.
R3Wood
Jan 28, 2026 03:00 PM
Brett Rauber
Oct 26, 2020 06:49 PM
R3Wood
May 7, 2015 07:42 PM
Jandreu
May 31, 2014 01:39 PM
