02 jaguar xk8 convertible small windows
Old May 31, 2025 | 09:42 AM
David Lawson's Avatar
Default 02 jaguar xk8 convertible small windows
My rear small windows will not roll up both sides and I find it strange that both will not function when the top goes up and down. I think that I hear the motors running when trying to cycle the small windows. Again I find it strange that both will not function. Oh and I don’t hear the bell sound when the top goes up. I use to hear that bell thingy chime when top is actuated. Battery is charged as well. The top works as it should just the small windows will not function up or down and in the halfway window position.
Old May 31, 2025 | 09:46 AM
Phil m's Avatar
Daft question but have you checked your fuses or checked for codes?
Old May 31, 2025 | 01:17 PM
Y2KJag's Avatar
Bad news - your regulators have likely failed. If you can hear the motor running a bit then they're trying to move the window. The "stuck in the halfway position" is a dead giveaway.
These regulators have some of the crappiest design in the world. The windows is operated by a cable. This cable wraps around a spool attached to the motor. The cable runs from the spool to a couple of pulleys. In a fit of idiocy Jag/Ford used a cheap plastic pulley with a bushing. This cheap-o pulley is the only mechanism that keeps the cable aligned on the spool. Over time that pulley's bushing wears and the pulley no longer rotates in the correct plane. It tilts. Once the tilt reaches a certain point the cable no longer winds correctly on the spool, the cable gets all monkeyed up (a technical term) and the motor jams. Alternatively, the plastic spool breaks and something similar happens. This is a known issue with these crummy regulators.
The only solution is to remove the regulator and repair it. Kits are available to replace the spool and pulley. However, I found it best to send the regulator off for a complete rebuild. If you're in the States there's a company that fixes them and replaces that plastic pulley/bushing with a metal pulley, an actual bearing, and a strong metal post. It will outlast the car. I can dig up a link if you want it.
It's a rather involved process, but doable with normal hand tools and a large dollop of patience. jagrepair.com has a wonderful write-up with pix.
Old Jun 1, 2025 | 06:30 AM
Jon89's Avatar
^^ Please provide that link. As these cars continue to age, more and more of the window regulators will fail and need to be refurbished....
Old Jun 1, 2025 | 02:41 PM
Gus's Avatar
Gus
Check the fluid level at the pump for your roof. If it is below the top embossed line fill it. The rams for the roof lift must complete the travel of the roof or both windows will not go up.
Gus
JagRepair.com - Jaguar Repair Information Resource
Old Jun 1, 2025 | 03:30 PM
MRomanik's Avatar
Veteran: Air Force
Try this- remove and reinsert the rear window relays in the trunk fuse box.
Old Jun 1, 2025 | 03:33 PM
Y2KJag's Avatar
10th item from the bottom.
For repairs: https://powerwindowrepair.com/
They also have an eBay presence and, IIRC, the price was slightly cheaper. Due to a brain f*rt I neglected to take a pic of the finished product. But the new pulleys were incredibly beefy. The thing arrived refurbed, re-greased, and ready to be installed (after I reattached the glass)
Reverend Sam
Mar 9, 2026 01:08 PM
2003RagJag
Apr 7, 2025 12:14 PM
Theo14
Jan 28, 2025 06:38 AM
pk4144
Dec 5, 2016 12:10 PM
jdperformance
Oct 21, 2014 10:01 PM
