'02 XKR Electrical Quandry
Old Jul 28, 2008 | 06:59 AM
wcben's Avatar
Default '02 XKR Electrical Quandry
My Dad (who is 72!) 2 months ago purchased an 2002 XKR, it's his dream car, he's always wanted a Jag, it's a beauty as all here know!
Here's the concerns...the steering column doesn't adjust by the controls on the side of the column but it does go up and, down when in the "auto" position. There's no sound of a telescoping motor running with a stripped gear.....the domelights do not work and neither do the windshield washers (they're suppossed to be on the same circuit) but, there's no problems with shifting or the ignition lock which are on the same circuit as well. Fuse 7 in the drivers side facia fuse panel blows immediately when inserted which is the dome/washer/locks circuit. Is there a commonality here or, am I chasing two separate problems? I'm very familiar with troubleshooting as that's part of what I do all day with audio equipment and, systems, I'm just not familiar with the Jag's schematics and peculiarites.
Any help is greatly appreciated.
Ward
Old Jul 28, 2008 | 01:07 PM
test point's Avatar
Default RE: '02 XKR Electrical Quandry
Has there been work on the top latch hydraulic hoses? When I put the latchassembly back together I pinched a wire and had exactly the same problems. Pulled the assembly and made sure wires were clear which fixed the problem.
Old Jul 28, 2008 | 07:22 PM
wcben's Avatar
Oh! I didn't mention...it's a coupe.
Old Jul 29, 2008 | 12:42 PM
test point's Avatar
By 'PM Me' I meant to send me your direct email address. Large file.
Old Jul 29, 2008 | 06:29 PM
wcben's Avatar
Default 2002 XKR Electrical Quandry
now it won't let me pm you.
Old Jul 29, 2008 | 07:42 PM
test point's Avatar
Default RE: 2002 XKR Electrical Quandry
Board is all screwed up. I got your address and sent the information. Let me know if you do not get it.
Old Jul 29, 2008 | 07:44 PM
wheeble's Avatar
go here.
http://p4-8057.uk2net.com/jag/XK8%20...ec%20Guide.pdf
It has what you need.
Old Jul 29, 2008 | 08:43 PM
wcben's Avatar
Thanks so much for the help guys! Do these symptoms usually end up being a BPM replacement?
Old Jul 30, 2008 | 08:47 AM
test point's Avatar
No, they usually are grounds beyond the BPM. In terms of power feeds, the BPM is only a logical switch.
99xk8guy
May 28, 2024 09:36 PM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
frank regalado
Sep 16, 2015 06:15 AM
mcdutch
Sep 4, 2015 03:38 AM
