'02 XKR transmission leaking, it started when freezing weather hit ?
Old Nov 14, 2018 | 10:11 PM
zray's Avatar
Default '02 XKR transmission leaking, it started when freezing weather hit ?
Anyone have this happen. Am loosing about a tablespoon overnight.
Do I just need to move to the Tropics ?
will be under the car soon to see where it's coming from . The transmission pan was dropped last summer for some maintenance, but no leaks for the next 6,000 miles, until the weather got down to 15 F.
Z
Old Nov 15, 2018 | 08:30 AM
michaelh's Avatar
There may be some clues in this thread by YYC:
https://www.jaguarforums.com/forum/x...4/#post1698698
Also contains a TSB posted by Bob (motorcarman) that may be relevant...
Old Nov 15, 2018 | 04:57 PM
oldmots's Avatar
Take a look under there and find the leak point first. Since the sealing points are plastic, they shrink in the cold and leak if they are at all questionable. Retorque the pan if its there, If its the electronics sleeve, you'll have to pull the pan to change it since the lock for the sleeve is inside the pan area.
Old Nov 15, 2018 | 05:36 PM
zray's Avatar
the PDF (attached to post #4 in the thread referenced by Michaelh in the above post) makes it sound like a leak from the electrical connector is due to an O-ring failure. The TSB makes no mention of needing to pull the pan in order to replace the inner and outer O-rings on the connector socket, or the connector sleeve.
Can anyone comment on this ???
Z.
PS thanks for the replies !!!
Old Nov 15, 2018 | 05:47 PM
NBCat's Avatar
To remove the electrical connector sleeve from the ZF 6HP26/28, the pan must first be removed.
Old Nov 15, 2018 | 06:01 PM
zray's Avatar
I don't have that transmission, the '02 XKR has the 722.6
Z
Old Nov 15, 2018 | 06:36 PM
michaelh's Avatar
Hi Z,
There are some pics here courtesy of franasia (benzworld) that may help. It's a looong thread!
https://www.benzworld.org/forums/2809739-post8.html
Judging by the position of it there's no need to remove the trans. sump
Jawvdp
Feb 6, 2019 05:06 PM
Steve W
Mar 13, 2018 11:01 PM
Spikepaga
Jan 18, 2018 04:25 PM
annamiata
Jan 2, 2018 10:06 AM
macudc
Feb 10, 2015 09:53 PM
