03 XK8 FYI warning on Injector rail crossover line
Old Nov 21, 2014 | 03:32 PM
brgjag's Avatar
Default 03 XK8 FYI warning on Injector rail crossover line
On my 03 XK8 I had my rails and injectors sent out to injectorRx to be serviced for leaky pulsation dampeners and general maint.
On that hard rubber cross over line on the front of the fuel rails. Mine was leaking under pressure check. I was told that the rubber line has a plastic line inside it and that in my case it had cracked and was leaking under their pressure test which if I recall is more than standard pressure the system makes. He said mine was leaking and needed replaced (cost 10 bucks to fix). Mine was prob broken because I handled it as it it was just a rubber line, letting it bend more than it should have if I knew there was plastic (prob brittle at 96k miles and years of heat on it) in it.
So beware when handling that line that crosses over from one rail to the other.
Old Nov 21, 2014 | 03:53 PM
cjd777's Avatar
BRG, thanks and that was one of my concerns when I did a replacement thermostat housing on a 2002, the top did not have any clearance on the crossover rail. I did realize bending it back was not a good idea and thanks to your post, I now know why.
Wayne
Old Nov 21, 2014 | 04:32 PM
brgjag's Avatar
I suspect it not a rock hard plastic that is in it, must have some play in it just based on where it is. But like I said at the miles I was at I am sure it got a little hard and I did not handle it with much concern if I had known.
99xk8guy
May 28, 2024 09:36 PM
mrplow58
Jan 21, 2024 05:53 AM
rsperle
Sep 12, 2015 08:37 AM
giandanielxk8
Sep 6, 2015 07:21 PM
