03xkr turn key get a click sound wont turnover, thoughts?
Old Sep 3, 2013 | 04:57 PM
deadboy1977's Avatar
Default 03xkr turn key get a click sound wont turnover, thoughts?
On my 2003 jag xkr, when I turn the key all I hear is a click….no starter turnover. Battery is good, pretty new and charged.
The click sound happened once or twice before…I was parked at work and went to start the car…click, tried again click, tried a third time and it turned over………………Another time it went click then I went back into the store to look around and tried it an hr later and it turned over.
Old Sep 5, 2013 | 09:32 AM
all connections in trunk checked and clean, fuses OK.....called the dealer and the service manager stated that the connection at the starter has been troublesome on these years.....anyone else hear of this problem or have it? usually starters have just booted studs and nuts.....corrosion there perhaps?
Old Sep 5, 2013 | 10:30 AM
Friarshuck's Avatar
Definitely worth checking. If your battery is good and all connections are also good, next thing I would check is the starter itself.
Good Luck, Hope you find your problem.
Old Sep 5, 2013 | 11:00 AM
RJag's Avatar
Sounds like you're hearing the relay but can you check for voltage on the far side of it?
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
dcvickers
Sep 2, 2015 06:14 PM
