04 XKR Felt Help
Old Jan 18, 2015 | 09:54 PM
rperformance's Avatar
Default 04 XKR Felt Help
Last summer a mouse got undrer the hood and chewed a nasty spot on the felt covering that goes on the front of the utility box located behind the left strut tower. It drives me nuts when I open the hood. I can't find the part number and doubt any dealer would stock it.
Any ideas on where to find one? Anybody have a clean used part to sell. No XK Jags in my area Junk Yards. Thanks, Jim
Old Jan 18, 2015 | 10:05 PM
ccfulton's Avatar
There are several cars being parted in the classified section so you might try one of those.
I would expect you will find one as this part is not likely to be in high demand.
Old Jan 18, 2015 | 10:32 PM
WhiteXKR's Avatar
Whatever that material is, it must be mighty tasty to the little critters. I have seen several cars, including my own, with the exact same damage. Some thin black linen, carefully trimmed and fastened with headliner adhesive can make a pretty decent patch that is barely noticeable.
Old Jan 19, 2015 | 07:40 AM
Jon89's Avatar
I would set some traps, do some skinning and tanning, and then cover that utility box in fresh mousehide....
Old Jan 19, 2015 | 03:57 PM
oyster's Avatar
Hi.
I used some PlastiDip on mine. Was worse than yours, but the paint made it look pretty good.
Old Jan 20, 2015 | 06:14 AM
jamdmyers's Avatar
This is my mouse trap to keep the critters away, she has the run of the garage.
Old Jan 25, 2015 | 10:27 AM
Autobahn kid's Avatar
I can help. Rescued one for you yesterday.
JM
Old Jan 26, 2015 | 08:38 AM
I really apreciate it. Sent you a PM. Thanks Jim
Old Jan 26, 2015 | 08:44 AM
WhiteXKR's Avatar
Slip some scented dryer sheets behind the replacement. That should keep it from happening again.
Old Jan 28, 2015 | 12:17 AM
That's a good idea, I'll stuff a bunch left from winter storage behind there. Maybe a plastic bag Time Capsule too with a Build Sheet, History, and a few photos for the next generation to find.
BTW: I learned something about recylers. I was told when they disassemble the cars and pull the engine, that they cut right trough that area. I got lucky and someone rescued the part.
indi4ever
Oct 8, 2015 10:23 AM
Rocky15
Sep 28, 2015 04:59 PM
dieseldoc
Sep 28, 2015 01:17 PM
Rocky15
Sep 26, 2015 07:40 AM
hhv00586
Sep 18, 2015 08:59 AM
