0442 On 2004 XKR
Old Jul 18, 2025 | 08:00 AM
MikeGriese's Avatar
Default 0442 On 2004 XKR
My car is throwing a consistent 0442 (small EEC leak). I have replaced the fuel filler cap with a new OEM replacement with no joy. The dealer ran a smoke test and claimed not to find any obvious leaks. Does anyone have some ideas on where to look? One other potentially pertinent bit of information is that I got a pretty strong fuel smell for a short time while driving the car hard - twisty, hilly roads with lots of acceleration and braking. Seemed like something purged a bit of fuel during the drive. It only happened once and has mot recurred, but then I haven't been driving the car as spiritedly.
Thanks!
Old Jul 18, 2025 | 12:04 PM
xalty's Avatar
didn’t try hard enough. most common one i’ve run into is the stepped hose on the evap flange
Old Jul 18, 2025 | 01:28 PM
pcolapacker's Avatar
I had it coming out around o-rings into cannisters.
Old Jul 18, 2025 | 04:26 PM
Y2KJag's Avatar
Fuel smell often indicates the purge valve located behind the left front wheel. Mine had that AND a bad canister valve (rear of car), AND a cracked RH side canister AND a flat o-ring on the LH side canister.
Old Jul 18, 2025 | 09:34 PM
MikeGriese's Avatar
So basically look at everything...
Quadcammer
Apr 25, 2023 08:06 AM
mhminnich
Jan 14, 2022 07:01 AM
dsd
May 3, 2017 04:59 PM
chip
Dec 2, 2014 10:50 PM
mikemrmike
Apr 25, 2014 07:40 AM
