05 XK8 srs airbag light on
Old Jul 18, 2017 | 07:47 PM
zidjan's Avatar
Default 05 XK8 srs airbag light on
Hi guys,
My airbag lights was on since last week.... it was fine the first 15 minutes and then the light blinks 3x and 2x and then constant on until I turn off the engine...I pulled 2 codes with my icarsoft
Any idea, how do I diagnose this?
My battery was replaced January 2016 so I don't think it's the battery.
ALSO does anyone know any good independent Jag close to Thousand Oak California??
Attached Thumbnails 05 XK8 srs airbag light on-20170716_113501.jpg   05 XK8 srs airbag light on-20170716_113452.jpg
Old Jul 18, 2017 | 09:42 PM
dsd's Avatar
dsd
I think the sticky has the Airbag Flash Code Keys. You are seeing a 32
Old Jul 18, 2017 | 11:25 PM
prettybluefin's Avatar
I think if you call Minna Gallery, his father is a Jaguar mech. They are in the valley...
Old Jul 19, 2017 | 07:02 AM
avern1's Avatar
The most reliable is the flash codes. That said, I recommend rechecking the flash code count. The flash code repeats, I think 5 cycles before going solid.
The guide for flash codes doesn't have a Code 32. Once you post the new results we can help out from there.
Old Jul 20, 2017 | 09:13 AM
fmertz's Avatar
Are you not trusting the second message? I believe the air bag system need to know if your safety belt is on, so there is wiring/switch in the belt buckle. I believe there have been posts about this before, something about the wiring and a plug under the seat.
Old Jul 20, 2017 | 10:30 AM
Originally Posted by zidjan
My airbag lights was on since last week.... .....
Regardless of what you use to read codes on a Jaguar, the only reliable decode is the Jaguar DTC listing. Here's the extract for the two codes you reported:
B1318 is not related to the SRS and B2434 should be accompanied by Flash Code 51.
Check your Flash Code count again. Possibly misread or you may have additional SRS issues.
Old Jul 20, 2017 | 12:31 PM
zidjan's Avatar
I just rechecked my flash code.... I got 4/1 ....then 5/1 what does that mean? B2434 then? I have a ground short from the seatbelt? any ideas how to look into this and fix it?
Old Jul 20, 2017 | 12:44 PM
My SRS Flash Code lookup doesn't list 41. The additional information for 51 + B2434 possible causes is:
Connectors: FC009, SD001, SD020. Driver Safety Belt Buckle Switch.
Harnesses: Instrument Panel. Driver Seat
Old Jul 20, 2017 | 01:49 PM
zidjan's Avatar
Ok..I might be mistaken then....buckle switch...hmm...got any ideas how to change the switch??
Old Jul 20, 2017 | 02:14 PM
I'd check the connectors first.
Old Jul 21, 2017 | 01:44 PM
zidjan's Avatar
I did that and it seem everything is tight ...I don't feel anything loose.
Old Jul 22, 2017 | 05:42 PM
bazjag's Avatar
These threads might assist
https://www.jaguarforums.com/forum/x...e-51-a-184787/
https://www.jaguarforums.com/forum/x...sh-code-73436/
AFAIK the switch in the seat belt buckle can't be replaced.
Old Jul 23, 2017 | 11:36 AM
zidjan's Avatar
Thanks this helps a lot...I'll try this tonight
Old Jul 23, 2017 | 12:19 PM
RaceDiagnostics's Avatar
If your seat is in its fully lowered position, try raising it by 1/2 an inch.
The seat harness design is a total bodge, the seat mechanism pinches the harness when in the fully lowered position.
Old Aug 6, 2017 | 07:04 PM
zidjan's Avatar
Hey folks, I finally just had the time to take the seat out, inspect and clean every connector on the seat especially, the seat belt receptacle connector, however I am still getting 5-1 code, it's also rather weird that if the weather is cool, it won't flash until the it's getting warmer. Does this mean my seatbelt buckly could be defective or the harness? which harness do I need?
Old Aug 7, 2017 | 06:08 PM
bazjag's Avatar
It's a lot of work removing seats but swapping the passenger and driver seat belt buckles could isolate whether it is a buckle problem. Hopefully someone can suggest an easier way of eliminating the buckle as the cause. I was lucky that separating the cable connectors and cleaning with electronic cleaning solvent cured my 51 fault
Old Aug 14, 2017 | 08:43 PM
zidjan's Avatar
So I swapped the buckles and I still get the 5-1 code...any idea what I should check next?
Old Aug 15, 2017 | 04:31 PM
Did you try raising the seat yet?
Old Aug 15, 2017 | 06:13 PM
bazjag's Avatar
Some more discussion here -
https://www.jaguarforums.com/forum/x...ev-sam-115939/
It looks like a harness issue now that you have confirmed that swapping buckles doesn't resolve the fault. Reinspect the under-seat harness thoroughly to see if there is any damage from pinching as suggested by RaceDiagnostics. Try cleaning all contacts again.
Is it possible to disconnect the harness and check for continuity for each pin end to end?
Other than that I've run out of ideas.
Old Aug 16, 2017 | 06:05 PM
zidjan's Avatar
Looks like a trip to the shop is warranted then...I didn't know what I was looking at in regards with the harness.
