1997 jag xk8 conv.
Old Mar 30, 2011 | 05:44 PM
Yancyb's Avatar
Default 1997 jag xk8 conv.
the left side window will not go all the way up and stay. sometimes it does and then when i get out it , by itself, drop down a few inches. all the other windows work correctly. i even let the top down and back up to see if that maybe would reset everything.
Old Mar 30, 2011 | 06:12 PM
test point's Avatar
You may have a battery problem or maybe the window position memory has just been lost.
Because of the high current requirements of the window motor it can draw the battery voltage on a failing battery below the threshold of reliable module operation.
First, try to reset the window memory with the engine running. Press the 'up' button until the window reaches the top and hold it until you hear a 'click'. Lower the window and hold it until you hear a click.
If that doesn't work have the battery load tested at an auto parts store.
. . . and welcome to the forum!
Old Mar 30, 2011 | 06:32 PM
Yancyb's Avatar
Default 97 jag xk8 conv.
thanks. i will try this.
Old Apr 7, 2011 | 05:48 PM
Yancyb's Avatar
Default 1997 Jag xk8
It worked. Thank you so much. Now I have another minor issue. The cig. lighter doesn't work. The fuse is good. Any thoughts. Thank you.
Old Apr 7, 2011 | 06:28 PM
Yancyb's Avatar
Sorry about so many questions. This Jag belongs to a friend and she is learning. Can you tell me if there is more than one Cig. lighter port on this Jag. It appears the one she knows about is broken and will have to be replaced. She is on a trip and can't keep her phone or Garmin charged. Thanks.
99xk8guy
Sep 29, 2025 10:51 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
Rick Michael
Sep 6, 2015 06:53 PM
edtexas
Sep 5, 2015 10:49 AM
Bowman
Sep 3, 2015 03:17 PM
