1997 xk8
Old Mar 24, 2012 | 04:56 PM
mike mitchell's Avatar
Default 1997 xk8
car has 64000 miles, and just had timing chain, water pump etc. replaced. its like the car has a ghost. the warning gauges, like bulb in rear out, when they are all working. also, when car is driven for over 10 miles, the temp gauge flutters, then drops into the red at idle. temp stays the same, and the tach stays at 700 rpms. does a computer need to be re booted, or something?
Old Mar 24, 2012 | 04:59 PM
oldjaglover's Avatar
It does do some re-learning/resetting, but not that much. How much have you driven it/started it since it rololed out of the shop?
Sounds like a "connection" issue.
Old Mar 25, 2012 | 08:28 AM
Beav's Avatar
Tail light holder ***'y has ground wire deficiency. There's probably a post or two here with pictures to show how to add/repair a proper ground. Pretty typical for a lot of european cars.
Temp gauge sender wire may be loose at the sending unit.
Tach - I've seen several, myself included, mention the instrument panel connector loose/needed reseating.
Old Mar 26, 2012 | 12:54 PM
thanks for the help. just put 7500 into this 97 xk8, and these little things like driver window only holding its program for one or door openings, is driving me nuts.
Old Mar 26, 2012 | 01:02 PM
somebody told me to disconnect the battery for a minute, then reconnect, and drive it to re boot it. hard to believe. thanks for your help. wish you guys that know what youre doing lived around me.
Old Mar 26, 2012 | 01:06 PM
If your battery is tired it will play havoc with all those sensitive electrical components.
tlynch
Dec 31, 2020 01:58 PM
mikiep
Dec 20, 2019 07:37 PM
speacock
Oct 3, 2015 11:15 AM
Johnken
Oct 2, 2015 10:12 AM
42Ajd
Sep 26, 2015 07:04 PM
