1998 JaguarXK8 tail lights problem
Old Nov 1, 2022 | 12:14 PM
931Kyle's Avatar
Default 1998 JaguarXK8 tail lights problem
1998 JaguarXK8 right rear tail light bulbs are all blinking when I turn left signal on , right site is okay. After I swap left module with light bulbs to right and right to left everything is working fine. But left module is not fit to right tail light housing. Could be any ground issue ??
Old Nov 1, 2022 | 12:43 PM
michaelh's Avatar
Hi,
Entirely possible:- the lamps all share a common ground which isn't really up to the job.
Check out this thread from hacker-pschorr:
https://www.jaguarforums.com/forum/x...83/#post189210
Old Nov 2, 2022 | 02:34 AM
Pistnbroke's Avatar
The earth is disconnected ..broken.
If you put a wire from a good earth to what should be earthed you will cure it.
Old Nov 4, 2022 | 02:12 PM
931Kyle's Avatar
Thumbs up Jaguar XK8 tail lights
Negative pin from female site connector coming from wiring harness was bad . R&R connector . Problem solved .
Old Nov 4, 2022 | 02:16 PM
931Kyle's Avatar
Bad negative pin from female connector was bad . R&R connector . Problem solved .
e1ectric
Sep 6, 2021 11:02 AM
salP3082
Jun 23, 2015 12:11 AM
jimbo94
XJ40 ( XJ81 )
May 5, 2015 09:04 PM
joebit
Feb 27, 2015 04:16 AM
jayb1rd
Sep 23, 2011 10:49 AM
